noice. where in canberra did you take those pics?
There's a boatramp in the carpark that's next to the boathouse restaurant.
Took me ages to find somewhere but I felt I had to take some since Siknis from CC detailed it for me yesterday!
nah you dont need GTR gaurds to make the front bar sit nicely, simply redrilling/grinding 2 wholes in the GTR reo bar (12mm to be exact) will bring the front bar foward enough to fold the sides of the bumper up to the gaurd leaving no gap and over hang :D
What does the gap with the headlights look like with this approach? Very clever by the way :)
.... but to bad for the 20 in the R32 :D
Because you never went in a properly modified example :) Should have wound up the 2535 to 240rwkws, from there and higher they start to feel decently quick :)
haha I wanted 230rwkw but yeah it wouldn't get there which just made me not want to keep it/modify anymore, especially after all the work/time I put into it with all the good parts
Most Trent (Status) could get out of it was around 215rwkw on 1.2bar, it wouldn't go any more. Drove great, had plenty of power and was fairly responsive for a 20, probably because of the cam gears but still didn't do it for me
After all those mods and money spent I could sit with my cousins stock R32 GTR, with cat back exhaust, chipped ECU and pods :D
My GTR now blows that, stock with exhaust, PFC and 14psi makes around 260kw at all 4. They just don't compare, even if it is an R33 :)
I still love it, always will! You just can't beat the look of a clean R32 with fat wheels but performance wise, you can't go past a GTR :D
That's my story
Well curse you because my XD9s look hopeless on my car compared to yours. So just bought some RE30s, hopefully they look ok, if they dont i dont care as i just want some nice light wheels that fit :D
bahaha I noticed they were for sale
Where did you get the RE30s from, are they good size/offsets?
They better look like these
Didn't you have RegaMaster wheels before, they are fairly light in decent sizes?
Yeh the Rega are an awesome wheel and the same weight give or take as my old LM GT4s. Only prpblem is the spoke design and offset of mine mean they dont clear larger aftermarket brakes. The same problem as the XD9s, fine over std brakes, not so flah without spacers if you want to run track brakes.
The RE30s are same as my XD9s, 17 x 8.5 + 30. According to Rays they are suitable for bigger aftermarket brakes on a Skyline, and have a better spoke design to clear calipers. Would love to go the sort of offset you ran on your GTSt but i need the suspension travel and gaurd clearance on the track.
LOL, yes. Next years GP i might try and steal some Rays wheels out of the Williams pit garage :)
hey guys last night i was pretty bored so i reversed my car out in the drive way and here are the ne wheels on it and yes thye are SSR PROFESSOR SP1,
they are 17+9.5 all aorund with a +12 offset, tyres are bridgestone potenzas re-01s with about 70% tread and here how the car looks now, ive just slapped them on and havnt touched it yet as i just put them on yesterday but yer they look really nice, sorry for the pics are pretty shit but will get better ones soemtime dutuing the week
they come out pretty nice but i can always get that really fat ass look by going a tyre like 275 or even 255 but i think i will stick with the 245 as they are spot on and still look fat and stocky on the gtr
car needs lowering liek big time but was going to do it tonight but i think looks liek ti will be tomrorow or wednesday but will keep yous guys informed but here is some pics of the wheels on the gtr
cheers tony
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
