^^What wheels you got there?
Looks very nice with the lip and black wheels with red lip looks tuff as!
As Nisskid said Lenso D1R's. Sold them to someone the otherday, just grabbed some XD9's yesterday 18x9+20 with 215's stretched on. Waiting on my 10's!
how thick are ur sway bars and how much stroke do ur dampers have? im assuming thats at full droop?
Lol, honestly don't know about dampers and all that. I haven't put sway bars in either..
because they are cheap crap lol
ok as street wheels, but for the track with higher stress/grip/heat levels i wouldnt trust them
I'd trust a brand new set of Drift Teks over a second hand set of Jap rims anyday, who knows what second rims have been through.
