32s i found on the net. my 32 is black with stock rims haha
RB20 GT2535 18psi 300whp - the car's 20 years old this month!!! they don't make them like they used-to
ratty drifter, porn
first dibs on this kit if I can find it!
local track radial tyre record holder (in japan) lightened to just over a ton and RB20 with 25 turbo.
cheers
cheers
Front bar vertex
side skirts vertex
and rear bar looks to be final konnexion
vertex parts are easy to get, ive got the side skirts and rear bar on my car
and final konnexion im pretty sure are also avaliable at some of the body kit places to
more details on this thanks.
Cool, I'll do my best but the pics are big as they get on the website I think. I got the pictures from a blog written by Tochi, from shop called YMS. This HCR was brought in by a customer (Super NOW) ‘NOW’ is phonetically spelled for ‘na-u’ (na-u-i), which is ‘trendy’ in Japanese. Who just got the track record for Nikko circuit 38.902 sec for radial tire TOYO R1R (I heard from a local Toyo guy that this is not released as a semi-slick any more, I got them on my car and it’s so soft like a semi ). This car also does the Tsukuba 2000 track in under a minute J sweet.
I read Japanese so I surf the Japanese side of the web.
The blog read something like… the car came in for a check and a possible retune, had the diff ratio changed, different boost controller installed. Base figure was 280hp at the rears, after the tune was 300hp on same RB25 stock turbo on a/m exhaust manifold. And came in later for another tune with an adjustable cam gear. The power was measured by dyno-pack. he might have this thing calibrated to show power at the flywheel, I donno. When I read some of the power figures on his site, all the power readings seems to be high ish. there isn't much info on the site apart from the motor. looks like lexan for glass atleast.
Im putting up all the pics from the web http://blog.goo-net.com/tochi/daily/200909/12
hope you enjoy!
P.S thanks for the kit info
Yeah i also dont rate chromies AT ALL! Your current rims look good on the car though. Black on black can look good but sometimes the rim style is a bit lost cause they don't stand out. But time attack's are fkn sweet!
OOOH those are DAMN SEXY!!!!!!
thanks mate
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
