Here is my car turned around and getting ready for the gear box to go in soon
I will do a build thread for this car soon enough. The 30/26 is just about ready to go
The front bar is just zip tied on at the moment but it will be held on correctly soon. Im just going to a friends place who has a hoist to put the gear box in and will do the bar at the same time
Edited by waxracing
my hcr32
with 18 inch alloys wich I do not prefer as they are very weighty and a tad oversized
but still not happy with how it looks atm, needs serious lowering + 17inch dished alloys, but since I'm using it as a daily driver, and my front lip is already kissing the 15 speedbumps I have to cross every day, it will be scraping like hell :nothappy:
Yes I know it needs more low.
First track day at Sandown, cars best lap was 1.27.10 on kumho ku36's
Active aero front grille :) Needs more self tappers
Heathcote drags 13.10 @110mph on same tyres (yes my rear door is a different colour)
dude what are your wheel specs?
there they are 17x9 -5 F and 17x9 +25 R, atm im running +10 at the rear, and ive lowered the front as well as pulled the guards out further to clear the wheels at the front. when ur running as much lock as i am with 235/45's u kinda have to push them out wide like that. they sit a lot better now tho.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
