Here is my car turned around and getting ready for the gear box to go in soon
I will do a build thread for this car soon enough. The 30/26 is just about ready to go
The front bar is just zip tied on at the moment but it will be held on correctly soon. Im just going to a friends place who has a hoist to put the gear box in and will do the bar at the same time
Edited by waxracing
my hcr32
with 18 inch alloys wich I do not prefer as they are very weighty and a tad oversized
but still not happy with how it looks atm, needs serious lowering + 17inch dished alloys, but since I'm using it as a daily driver, and my front lip is already kissing the 15 speedbumps I have to cross every day, it will be scraping like hell :nothappy:
Yes I know it needs more low.
First track day at Sandown, cars best lap was 1.27.10 on kumho ku36's
Active aero front grille :) Needs more self tappers
Heathcote drags 13.10 @110mph on same tyres (yes my rear door is a different colour)
dude what are your wheel specs?
there they are 17x9 -5 F and 17x9 +25 R, atm im running +10 at the rear, and ive lowered the front as well as pulled the guards out further to clear the wheels at the front. when ur running as much lock as i am with 235/45's u kinda have to push them out wide like that. they sit a lot better now tho.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
