I'll put up some pics of the new 32 soon Marko.
Nah no build thread at the moment, might do one later.
Stefan 3M blue masking tape will be your best friend during assembly.
Its low tac so it won't damage the paint. But its thick so it will protect the fresh paint pretty well.
Cheers. Yeah, still rolling on Meisters. Was going to sell them to get something different at the start of the year, but decided to stick with them.
You importing a 32 as well?
On topic, some more pics from the downshift meet
Hey man, just wanted to say that this thing is really nice. I saw it at the downshift meet and out of 700 odd cars, there were only a few that interested me. Yours was one of them.
thanks for that anth i was thinking of using bubble wrap but ill try that for sure!
saw the bay today had no idea it was sprayed! very happy with the job. pics are of the bay straight off the gun. its getting buffed this week.
Cheers for the kind words.
Got a few cosmetic improvements still to make (the front bar being the most glaring off them), but am pretty happy with the overall look of the car. Just need to tidy it up a bit.
Will have some more decent photos coming up later in the month
No dramas mate. The front bar could do with a respray, but the car still looks the goods. It'll look even better once it's finished. Am I wrong or was it for sale recently?
What's done to it?
Haha u have an eye for detail. I'm actually surprised that the rta allowed for this plate to be registered
Exactly the same thing I said to the owner, he's been pulled over heaps of times too and no one has said anything about em.
But when you see the stance of the car it all makes sense.
18x11.5" miesters on the rear, 10s on the front and slammed hard.
What's done to it?
Hasn't been for sale in the last few years. Wheels were for sale at the start of the year but decided to keep them for the time being.
Mods are 25 engine, high mount turbo, suspension, brakes, computer, stripped interior etc.
Thanks guys, still got a few things up my sleeve to get it just the way i want it. I currently miss driving it badly at the moment :(
And sorry to all that have been restarting because of the pointer :P didnt think it would get so many people hahahha
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
