No mate - a gloss black GTR bonnet.
Carbon (FRP) is over rated and well past expirey date in my opinion.
Can make a car look tuffer but it's a bit like a mullet hair cut - bahaha
Seriously tacky cheap in construction too
cool cool, im hunting for something at the moment (as i needed to cut more openings / expand existing openings but didnt want to do it on an OEM plastic bar, so i sold that haha). Torn between just getting a fibreglass stock bar/lip replica or hunting around YJP for a bar (and side skirts to fill the "high" void that it seems to visually have)
keeping OT, she's looking a little naked sans front bar
