  • Replies 224
Posted Images
Dammit, I still can't come outright last if I try! I know I farked up the first shep laps, but I'm sure I got it right the 2nd time.
I demand points for the final shep laps run, ensuring that I come dead last out of everyone who completed every event! Thus ensuring the last place trophy is mine!
....there is a trophy for coming last isn't there? :cheers:
Was an awesome weekend! Had a ball with everyone as usual.
Thanks to Racingline and the organisers. Thanks also to all those who volunteered their time to help run the event. Without the volunteers, we'd all be in a lot of trouble.
Thanks to Al and Poite for letting me have a go on the skid pan. I really gotta learn how to drive fast while turning the wheel :P I think I put out a fair bit of tyre smoke with Al's car though :cheers: Now that I've driven Pete's car, I can truely appreciate how much skill it takes to make the car dance the way he does.
Can't wait for September!!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
