  • Replies 45
Meguiars products. Bit more expensive, but worth it. I use their polish and wax, and some interior stuff, looking for the plastic cleaner to do headlights, but can't find it anywhere.
I use cheaper stuff for tyres and rims, I have found all of the rim cleaners I have tried are very similar in result.
Mostly use meguires but I find as far as a quick polish goes i usually use Eagle one - it requires less elbow grease as Meguires and I cant complain the way it brings the car up.
Why oh why did i buy black haha
Originally posted by Adrian_perth
i use amourall
this blue liquid crap
some sought of special
car soap crap
which polishes at the same time
and boy does it work a treat!
adrian :P
OK, I've been biting my tongue for a while now, but I've had enough. You seem quite oblivious of this fact, but a web browser will AUTO WORD WRAP POSTS! Yes, its amazing, isn't it? Ever wondered why everyone elses posts take up 12+ words a line while yours only take up 35 characters? Its because they aren't pressing enter when they run out of room in the text box. And no, a new line is no subsitute for commas, fullstops and other punctuation.
I always thought room temperature IQ was all that's needed to post on forums, but its time to rethink that one.
Anyone who thinks I'm being too harsh should consider that well constructed sentences is the only thing seperating us from the teens on fast fours forums or the gits on irc. Written communication is vital to get your point across and poor form reflects on the forum itself. To quote a favourite forum of mine, "All of us who spend any significant time on the Internet know that written communication apparently is at the bottom of most message board posters' priority lists. From horrendous spelling to unrecognizable grammar, people make idiots out of themselves every day... and most don't care."
Nice one Gradenko, I think you speak from all us here. Adrian, I like you, but stop hitting enter, cover it up if your that unco that you can't not hit it.
Back on Topic:
I use Brasso for my headlights, it works good, but does need reapplication every 2 weeks to stay looking good. I've heard Mothers is good, but have no idea where to buy it from.
See'ya:burnout:
Meguires on the outside....
go to www.mequires.com and hunt down their online car protection guide... it asks you a heap of questions about where you live, what your cars exposed to, and (essentially) how much you care about your car.... adn then puts together a program for you based on your answers.... (not all the products listed are easily available here unfortunately, but with a bit of hunting, you should be able to get them, or something very similar)
On the inside, i don;t use much except for the armourall 'new car' cleaner.... similar to normal armour all, only with a lemon scent...
and Paul, I'm pretty sure you can pick up Mothers at Marlows, same as Meguirs, it's just that their range is pretty limited.... Wonder if somewhere like the PPG distributor would have a decent range of car care products?
Maybe one of Perths "premier" speed shops should start carrying it... :-)
(BTW, Speedworks/WheelsWorld stock Swissol cleaning gear, which is apparently better than Meguirs/Mothers, but not cheap)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
