  • Replies 67
PM sent Christian.
to all,
The CATs are now ready to go, and you dont have to wait until next Friday (GB close date) to pay and get your CATs. Just PM me anytime from now till close of GB with your address details and i will PM you my account details. The CATs will be sent out same day the payment clears.
cheers
Hi Micheal,
Are you in Sydney?
I bought the split dump off You, few months back. (Picked up from your bro)
If possible I will meet up with him again?
and pay cash to him?
Cheers,
PM sent!!!!
All PMs sent/replied to!
MintR33,
It depends on the amount of people that miss out and want a second GB organised. If there are enough people that ask for a second GB, i'll make one. The only way i can get these prices is by getting the cats in bulk. We'll see what the responses will be like by the end of this GB.
cheers
hi,
yes the small body 3" cats (pictured on the second post) are available in the group buy. let me know if you want to be put down for one, and for which car.
cheers
5" round body, 200csi metal inside - 706.2 CFM <<<=== that cat looks IDENTICAL to my 5inch body metal cat on the inside how ever i have 4inch in and out.. but i may be needing one for a r32 GTST bolt in.. 5inch round body one bolt in for r32 with flanges and temp sensor i will let you know today if i need it.. will speak to the guy todayseeing as its 440am
rb26s13,
yes it has the same insides as the metal cat (200ccsi cell), except the metal cat has a 4" body with the 4" substrate. thats why the catco metal cat flows higher (5" body, 5" substrate).
let me know definately and i'll add you to the list.
cheers
hi guys
just letting you know that the catco metal cats have all sold out from catco and there should be more coming soon from the USA shortly.
all the people in the list (list is up to number 15) have been catered for, as i have picked up the cats already but any new people who wish to be added for a catco metal cat, there will be a wait. i will find out how long this will be shortly and post it.
if anyone wishes to back out of the GB and has secured a catco metal cat, please advise me as it can be made open to someone else.
cheers
Hey BATMBL,
I bought one of your 3" large body cats a while back to put on my old R32 (which I've since sold) and was really happy with the product...now I'm trying to decide whether to go another for my R33 or go the whole hog and get a Catco metal cat.
So we know the 3" Catco metal cat flows 706CFM, but I'm interested to know the flow figures for the 3" big body ceramic substrate cat so I can compare & decide?
If you could let us know that would be great!
