Just thought I would share this video around here.
Its an RB20 NICS powered bluebird wagon at the ingham car show. Only reason I posted it up was that my brother used to own an R31 which had that particular engine in it before it go sold and stripped and put into the bluebird in question.
Made about 180rwkw in the r31 on stock ecu running a hitachi HT18 from a series 4 rx7, 2 rx7 cores welded together and 2.5" press bent exhaust. Running 13psi or some such.
Apparently it now runs an after market ecu and about 20psi. So maybe those really old nics arent as bad everyone makes out :dry:
Kills the rear tyres pretty quick too!
https://www.sau.com.au/forums/topic/120641-who-said-rb20-nics-were-useless/
THats something new I definately didnt know!
I guess the stock turbo had to be the major problem on them?
Stock turbo is SMALL. And the ECU is rather ordinary in its low state of tune. Slightly more restrictive intake than a silvertop. Basic engines are the same as a silvertop other than the 12 port head intake. Piss easy to get that sort of power with the ECU and a decent turbo sorted.
The NICS in my 200zr currently only pumps out 150rwhp, the stock ECU holds it back big time and the AFM is maxing with 10psi from an R33 snail....
I found the EXACT same thing with my NICS in both the Passage and the 200ZR - both with R33 turbos. At revs of around 6k upwards the voltage of the AFM hits pretty high figure of around 4.8v (which is 100% usage according to the SAFC) and as soon as it hits that, the thing is running so ridiculously rich it pisses and farts. Need to calibrate the AFM or use some sort aftermarket management to solve it.
Edited by frigjam
Yep, if I had a scanner I would post my AFR graph from the dyno run, at 5500rpm the fuel curve goes rich down to 11.0 (and power curve dies accordingly) then it leans to about 12.8 by about 7500rpm. At 12psi it basically blows the spark out and gets even worse power curve. 10psi is only about 7-8psi manifold pressure thanks to shitty 7MGTE supra FMIC Im running.
The SAFC2 wasnt really designed with the NICS in mind, the AFM setting (4 if I remember correctly) is for the R31 ECCS AFM which I believe is actually somewhat different (possibly different voltage range). I have an SAFC1 (5 dial model) but its got lots less tuning scope. Mine also reports 100% AFM usage by ~5500rpm.
Basically the options from here are full aftermarket ECU or R32 ECCS engine swap....both come in at about the same mark (~$3K) and I am leaning towards the latter as at least one of my injectors is leaking and she is getting some km's on her now...
Edited by 200zRRR
  • 6 years later...
I have a rb20 out of a 200zr which used to have the top mount inter cooler. It still has the original turbo! Was wondering if anybody can help me out as to what type it is?
I'm currently on the look out for a bigger turbo.
My car has a 700x600x75 inter cooler, rb26 injectors, autronic sm4 computer. Fully manulised Jacob four speed trans.
My issue is I'm struggling for kw. I only have 145kw at the wheels.
Can anybody suggest anything to help me out?
I have heard of putting spitfire coil packs and removing the inlet butterflies between the plenum and the head? Apparently they are not needed!!!!!!!
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
