  • 1 year later...
  • 10 months later...
  • 1 month later...
lol.
BTW does anyone know how to take the panel off an R32 without wrecking it? I have one of those light on ones, but it looks like it's stuck down with some sorta foam, wouldn't mind pulling it off and checking the electrical connections so I can have it lighting up properly!
  • 4 weeks later...
Skyline Light Up Tutorial
Doing this is at your OWN risk I take no responsibility for any damage or accidents which may occur throughout this tutorial, if you're unsure ASK, if you don't think you can do it DON'T
What You Will Need:
Dermal Tool (Rotary Tool)
Heavy Duty Dermal Cut Off Wheel
Dermal Sanding Band*
Rocker Switch* : If you want to turn it off and on
~ 14 High Intensity LED's ~$60+ from Jaycar or ~$20 from eBay, Check the light output rating
~6-14 Resistors: Pennies at Jaycar, You can use one resistor per LED or for every 2 (But if one burns out so will the other) Use THIS website to calculate the ohm's required for your array
Sheet of Experimenters Board: Try to get one that is long enough for the whole thing so you dont have to go through the hassel of putting them together
Some Wires: Try to get different colors for convince sake
Can of Paint: Match your color code (Recommend Autobarn Moorabbin, they can mix you up a can specific to your car and it's really useful for touch ups
Can of Lacquer*: Technically this isn't a must but it provides a nice shine & seal, also gives your that smooth feeling you have on your car
Painters Tape
Exacto Knife
Alright we first start with your Skyline Garnish after taking it off of your car inspect i and make sure it's all nice and clean, you will notice some faded paint on the letters start by sanding them off to get the best light through
Start by cutting the tabs off the back
Now cut the entire plastic backing out, enough to expose all the letters; For my next project I'm going to try to cut a small hole instead and slide the entire board in but it's up to you
This is what your Garnish should look like when you're finished
You can sand down the edges if you really want to but in reality no one is going to see the back it's only for your own satisfaction
Place painters tape across the lettering and run your fingers along the outside of the lettering it should tear the tape allowing you to just cover the individual letters
After cleaning the Garnish again prep your area for painting (preferably outside) apply several even coats of paint (I did 5 if I recall correctly but it's based on how happy you are with it) allow at least 20 minutes between each coat (maybe less or more depending on the weather)
*REMOVE THE PAINTERS TAPE OFF THE LETTERING BEFORE APPLYING LACQUER* I forgot to remove the tape before applying the Lacquer which was a pretty stupid mistake and it ruins the finish, not by a lot but it's a lot of work to fix. After you completed your final coat allow drying for a few hours before applying Lacquer; this will seal the paint and give it a nice Glossy finish
Admire your handy work before starting the hard bit
Cut down your Experimenters board down to size measuring it up to the hole you cut in the Garnish
I know this was an extremely crap soldering job; Solder all your LED's, Resistors and your wiring onto the board
Finally hook up the garnish to your car wiring in the rocker switch if you want to be able to turn it on and off, as a precaution I wired this to my ACC wire so it can only turn on while the key is in
Great walkthru there mate, thanks alot. I will try to fix my panel this weekend, hopefully it´ll work out fine :P
Just one question: what website to calculate the ohm´s?
  • 3 months later...
excellent guide, will do mine next week, anyone bought the leds from ebay
WHAT IS THE BEST SIZE LEDS TO USE 3 4 5 OR 10 MM
NARROW ANGLE 20 DEGREES WOULD BE BETTER THAN WIDE ANGLE 180 DEGREES I PRESUME
Edited by Dorifta
  • 2 years later...
sorry to res an old thread, but thought I would share a new way of doing this. I am going to use the new "tri" colour LED's witch is one LED with 3 colours, and 4 pins instead of the normal 2.
my plan is to have 4 try colour LED's to just lightly light up the "skyline panel" when the lights or parkers are on, then when the brakes are applied, another 7 tri coloured LED's will light up (same colour) and act as a brake light.
there will obviously be a 3 way switch to select between the 3 colours (red, blue and green). I will probably have this in the ash tray up the front so its hidden.
I've given it a lot of thought, and being an electronics geek I've already drawn up plans.
I've only just bought my S1 panel of a SAU member as I have a S2 R33.
heres a pic of the LED's I'm talking about, and I'll make sure I upload pics once its done and even a tutorial if enough people show interest.
I may consider doing this for others if they pay for all the parts :)
33 or 32? Im going to see how this one comes up first as I'm sure what I'm doing has never been done before, maybe I can help you out at a later date if your interested.
[/quotmoei
Are you talking to me? if so its an R32 I seen it on a R35 on the front Looks Beautiful
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
