ok so i purchased a set of second hand tein HR's for my R33 sedan...only to find out that the collars were ceased on the threads, and (get this) the previous owner had fitted lovell springs too the rear (for a softer ride), but really didn't change any characteristics of the comfort level.
so after buying some brand new tein springs from my local fulcrum stockist, i got a mate to fit the new springs in. (this is after i had a red hot go at f**king them). i thought it'd be easy as to do, with the right tools, but it turned out that the previous owner had not only put very wrong springs in, he had also used standard top shock mounts to hold the spring in (which was far from sitting right).
so custom top mounts were made up (for a small fee) and we ditched some of the top rubbers in order for a more responsive ride. once all was done i was very happy with the end result.
so i borrowed some "c spanners" from a mate and went about lowering my car. i started at the rear...and spent all this time/effort winding the collars the worng way. to in-effect i had unknowingly raised my car. :(
i consulted a friend...and he pointed me in the right direction. i then went about "LOWERING" my car, starting with the rears. all good! when it came to the fronts, i realised, after much persperation, that the collars were ceased on the threads...AGAIN! :P
so off i go back to my friend with the tools/know-how. he rectified the problem well and good and gave me some sound advice.
so i have recently lowered my car since that time and played around until i had the right/practical height.
now the problem i have encounter is the rear springs (new tein product) are too long, thus meaning at the lowest setting on the thread, the car is still way high. :D fronts are fine.
has anyone encounter the same/similar problem (spring wise)???
i was thinking about getting the spring compressed. like heating it in a vice and shortening it. professionally done of course. :)
any comments
https://www.sau.com.au/forums/topic/120892-rear-springs-in-my-teins/
here's a pic. :P
the gap between the top of the tyre and the guard is too much.
i want it level, front and rear.
i know its more body styling, but you can see that the front is way lower than the rear. sitting like a 1tonner
Edited by sedanlover
Shoot man, just take the springs out, they aren't doing anything at that height that's for sure. Probably isn't the springs holding it up anyway, it's on the bump stops. Better take them out too.
In fact, hang the expense, take the shocks out all together and stick some blocks of wood in there, probably ride better anyway. Certainly wouldn't handle any worse.
At that height it's probably loosing around 15 rwkw from excessive drive shaft angles. The tyres will last a few weeks at best, chassis cracks are just around the corner (nice pun hey?). The bump steer must be astronomical, not to mention the lack of traction for acceleration and braking.
Hope you don't want to drive it very fast.
:D cheers :)
PS; Low is slow
Edited by Sydneykid
LOL @ SK
goddamn thats golden.
Personally i think the car is too low mate. Maybe you should jack it up and take a chance on looking uncool and put up with better handling, suspension and tyre wear, as opposed to the opposite. Also i would give it about a month before your running on steel belts on the i/s rear tyres. Could be sooner depending on how many skids you rip for your mates/random specatators.
Not only does he know everything, hes also a comedian. These forums would be boring without SK.
its not that f**kin low...geez
1. i don't have those wheels on my car. (they were temporarily borrowed off a mate)
2. i'm running 300zx wheels with 50 profile tyres.
3. its not on bump stops.
4. the lowest part is the middle resonator on the exhaust =70mm off the deck. thats the only trouble i have. front bar is slowly wearing away...only if i drive hard on a mountain run or something.
honestly its not that low. I'M NOT A POSER! :laugh:
it rides good. nice firm and responsive. i guess i can live with what i've got until i wanna get serious.
That's 30 mm illegal.
What are the centre of wheel to guard heights on all 4 corners. That's the way you tell if it's too low. Anything less than 350 mm front and 340 mm rear is too low for good handling, traction and ride.
>_< cheers :(
Edited by Sydneykid
Oh how I love people on track days saying I should "buy some coilovers, that cars way too high" then make them eat my dust... The suspension kinematics (the way the arm angles work in conjunction with C of G height, roll centre heights and lateral movement, camber change, et cetera) all go to pot if the car is lowered too much. As SK says, it's way too low for effective work, it's just a show car like that! No offence.
:) cheers :D
i just went and measured my centre of wheel to guard heights..
front is dead on 350, rear is 330.
the car sits at about ~110mm at the front bar, and part of the exhaust at the rear diff. (lowest points on the car)
will raising the rear to ~340+mm make a noticable difference?
the car already has the "lower front end" slope, im thinking the front might need to go up ~5mm too if i raise the rear.
and on topic - how do you mean your 4 door sits too high? high in reference to the centre of wheel to guard heights on a mini minor?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
