I have been reading on here, and heard a few other stories about Skylines getting stolen recently. It seems that the thieves have worked out how to get into them.
One of the reasons I bought a skyline was because they did not seem to get stolen as often as Commodores, but it seems they are the new favourite for thieves after Commodores and WRX's.
I have been trying to think of a way of disabling my car so it can't be started at all, but I can't seem to think of anything other than pulling out a few relays.
Does anyone have any ideas about pulling something off the motor to disable the car? It seems that alarms and immobilisers don't cut it anymore. I understand if people don't want to post up their little tricks (unfortunately, you don't know who is watching...) but I would like to hear from anyone that has any good tricks.
https://www.sau.com.au/forums/topic/121250-how-often-are-skylines-stolen/
  • Replies 50
Posted Images
No shit thieves have figured out how to break into them there's a howto on this very site...
I had some little dear sit in my car and steal the radio, while the (external) alarm went crazy.
So now I have a Jaycar Screacher alarm (110dB @ 2kHz) mounted INSIDE the car. Just to remind any similar sweet things that they really were not welcome in my car.
That is a pretty stupid idea, tell everyone how to break into a Skyline and hope people only use the information for legitimate purposes..... :D
An internal screamer is a very good idea. I might look into one. I had one in previous car, you don't want to be inside when it goes off.
install a killswitch. have two or three switches to bypass it. position them in the most unobvious place though. i would like to write up a DIY on how to install one but then it will give thieving c*nts a chance to see how it is installed and then easily bypass that. mines wired up a special way.
are you referring to the articile i wrote up sewid?
i have some suggestions on securing the car;
cut signal to TPS
cut signal to water temp sensor
cut signal to crank angle sensor
cut signal to eccs
pick any number of important sensor in your corresponding engine and put a kill switch where you deem necessary to break the circuit. the car wont start or run.
cut signal to TPS
cut signal to eccs
That is a very good idea. Any chance I could get a copy of that article? Can you send it to me?
Guys,
Just a word of caution.
Honest people are not the only ones that use this forum, THEIVES do to.
While I agree with the idea of securing your car from some scumbag, just remember the more information you disclose, even if it only says you use a kill switch over an alarm or electronic immobiliser etc can make your car easier to steal.
Be very mindful of the type of information you give out and the person you are giving that information out to. PM's can be just as dangerous. Do you actually know the person on the other end? Are they after help, or just after your car?
I have been involved with the car audio and security industry for over 10 years now and have seen to many times people openly discussing the types, locations and specifics of how to make their particular car " unstealable", more disturbing than forum discussion, is people at car shows/ displays/ race meets that ask what sort of security is on the vehicle and then are given that information.
So please BE CAREFUL.
As for my 2c on the situation.
For most skylines they would be required to have an Aust standards immobiliser fitted for insurance purposes. The immobiliser while effective can be installed in one of two ways.
a - it's in and it works, but you can locate the module etc
b - it's in, its works and you cannot locate the wiring/ module or other traces of it.
The better an instalation of any security product the more effective that product would be. Even a basic immobiliser if installed well can frustrate a thief long enough to not want to steal the car.
I would personally recommend an Alarm with built in immobiliser hooked to GSM paging with car shut down/ lock down and location functions. Not cheap, but a hell of a lot better than coming park to an empty car park space.
For those that want more information on Aust Standards and other things to look for in vehicle security (without specifics) please look at this.
http://www.skylinesaustralia.com/forums/in...howtopic=109240
cheers
frx026
Guest Mashrock
i didnt buy it to do the shopping, or to go out to a party or a club.
it dosnt leave the sight, or does not get left anywhere unattended.
but still i have security in place.
p.s. things like this can also be noted down by your switch on the end of your keys.
Edited by Mashrock
what is this article on how to break into skylines? or is it one of those 'if you locked your keys in your car' type articles? sounds like an interesting read. i'm not a car thief, these are just things i like to know about, so where can i see it/get a copy?
Modern immobilisers are generally good enough to stop randoms hotwirng your car. Of course, installers and mechanics tend to know ways around them after they poke around the car.
And professionals will just tow it away if its too hard to hotwire, which all the hidden kill switches in the world won't prevent.
Can someone please PM me the theory behind a kill switch, don't need to know where you have it etc, just need to know what it does.
I don't quite get how you can have a switch that disables everything when the components are still there.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
