Hey guys,
Just wondring if anyone has had any experience, or knows how good 'AutoGauge' meters are. I've noticed JustJap selling them for $79, and was just wondering if I would be buying quality or garbage. Any info would be cool.
Cheers
https://www.sau.com.au/forums/topic/121253-autogauge-meters/
autogauge are made by autometer. exactly the same gauge as the autometer, same internals and all, just cheaper price. some stupid new law in the U.S. that says if a company is making a top of the line product that is only aimed at a select market then they must make a baseline product of the same thing.
they also have to do it in the american pharmacuticals market. if they make an expensive drug, once the patent is up they must make a generic version of it.
Would this suggest it is actually a Taiwanese copy?
http://www.autogauge.com.tw/
Since 1969, Auto Gauge Co. has been the leading manufacturer of high-quality performance meters in Taiwan with the branding of "Auto Gauge" and "Susuki".
If you look on the Autometer site you'll see one of their gauge series is called Autogage, so perhaps some people are getting that confused with Autogauge, which appears to be a seperate company? Correct me if I'm wrong, this is just my opinion after a quick look on the net.
So IMO Autometer, Autogage = USA
Auto Gauge = Taiwan
Auto Gauge = Taiwan
I think you just solved the puzzle. :wave:
hahahah, sorry champ, but the chinese gauges arnt that great.
First day i got my car, i stuck in a chinese gauge like swoosh/type r etc and it read 6-7psi. I knew the car would be making 4-5 psi stock so i was like, wtf. Went and spent 100 bucks on an autometer and it read... 6-7psi.
Just my personal experiance.
Thats great, but we are discussing Autogauge, not the brand that you have bought.
There seem to be alot of people using them that are very happy, someone on the zed forum from memory did accuracy tests and the Autogauges fared very well
I don't understand your post. You're saying they aren't great, but then from your own personal experience you say they're just as accurate as the US made Autometer?
What is the problem then?
LOL, I am a n00b. I wanted to say the Autometer read the correct 4-5psi.
Blitz - I was an importer/reseller of automotive gauges about 2-3 years ago when I was starting out. I imported from several companies products, one of which included Autogauge gauges and accessories.
The problem that I found with the gauges in China was the calibrations they did. Often they didnt sit on zero (differences in air pressures from mountains in China where manufactured comapred to sea side melbourne maybe??) and they did over read boost. Thats just my general personal experiance.
In the end, I think in a market like gauges where precision and accuracy plays a big role, as long as you are comparing two plain gauges (aka, not defi or some cool feature having one) a bigger price will more often than not result in a better product.
Having said all that, if you just use the one boost gauge for all your testing (like using only a single dyno) and are well below the limit of the engine internals boost wise, I dont see a reason for a more accurate gauge being needed, as long as you always only compare with yourself (I am sure that kinda makes sense)
PS - I paid $100 for my autometer boost gauge from Autobarn. More than happy and I know its pretty spot on
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
