But are you using a 3ltr engine? Not sure if i did metion it or not, but my engine consist's of an rb26 head with rb30 bottom end
No - I've got an HKS stroker crank fitted giving just on 2.8L displacement (87mm bore). The hardware should permit the engine to venture north of 9000 rpm, so I imagine overall airflow should not be too dissimilar.
Good luck and keep us informed.
  • Replies 181
dont know what he was talking about there? twin HKS 2530s for GTR are most definately ball bearing. i have never seen one that wasn't or even heard of one. i guess it's possible that there was one, but i dont think so.
My guess is the trust turbos on the dyno graph are 518z with the 0.72 rear housing. I am not sure whether that is the 8cm or 10cm (or neither) which is how trust measure the rear housing but that would be my guess.
Maybe someone could convert the 8cm and 10cm to a/r.
i dont think there is such a thing as 518z in twin form for a GTR. it's either 517Z or 618Z.
If you basing the GT-RS vs T04Z on the graph comparo here... im not too sure.
Im still un-convinced by one dyno graph comparo with unknown spec'd motors.
Its too hard to make a call without the detail of every car used, and the subsequent modifications.
As you said, give you 704rwhp... thats 704awhp
So i dont see how it isnt what you are looking for.
gotta allow for front drivetrain loss on top of that 704rwhp to get awhp
gave matty spry a ring today but he's not to 'in the know' with set-ups so he couldnt offer me adivce. anyone know who else is a 'turbo professor'?
Far as im concered there is no loss at all.
There is a super recent thread on it aswell if you wanna take a look :)
http://www.skylinesaustralia.com/forums/in...howtopic=119673
I've seen a number of GTR's back that up aswell going from two different mods
twin high mount 2835 would give ya that extra kick in the guts
but form my experience on a 2.6 litre gtr motor twin 2835's dont hit full boost till 6k rpm
but on a 3.1 litre im thinking 4k rpm
2.6L 2835 combo is quite laggy but could be made to come onto boost earlier depending upon cam choice and tuning. With the RB30, they would spool up substantially quicker and would be a great combination. However, when switching from low mounts to high mounts the cost goes up considerably. The GTRS's and the 2835's are rated similarly, and therefore should make similar power.
I would stick with the GTRS's in a track car and enjoy the ride.
Also, there is little drivetrain loss difference between rwhp and awhp in GTR's due to the ECU-controlled torque split of the ATTESA system.
nowadays there is a 517z and a 618z.. how ever if my memory is still working there use to be a twin 518z kit you could buy for gtr's how ever the 618z's replaced them soo maybe thats wat they are?
Looking at the ski-jump profile of the graphs, I reckon all the chosen turbos are track refugees. And straight-line tracks at that. Willall Racing are into dragging as far as I can tell.
The shape of the torque curves would be interesting - nearly vertical I would think. It would make for some interesting driving if you come on/off boost rolling on/off throttle on the road. Even on a drag strip they would need to look at very tightly stacked gearbox ratios to factor in the effective speed range(s) of the chosen turbo(s).
I do find it interesting to see their results from an academic viewpoint, as it highlights the ability of one setup to generate significantly more power across the range, if not the biggest outright number. GT-RS looks the best in that regard.
Also, comments made beg the question for the HPI exercise - do you match the turbo to engine, or choose a turbo and then work out what spec the engine needs to be?
cheers
Dale
There is a super recent thread on it aswell if you wanna take a look :D
I read that thread at the time and I had a couple of difficulties. The main one being switching/pulling the ATTESSA fuse doesn't remove all of the 4wd train losses. You really would have to remove the transfer case completely to achieve a 100% result. Secondly there is loss in the rollers themselves, so no matter how hard you tie the car down, there is always some slip. The slip differences between 2wd and 4wd can mask other factors. For example you may have more slip in 2wd hence the power reading is lower than it really should be.
As posted many times we have done a couple of engine dyno versus roller dyno versus hub dyno power runs. The % loss method is (as many have pointed out) totally illogical. Newtons law (fire up that high school physics) says energy is transformed not lost. So the kinetic energy (torque if you like) has to be transformed into some other type of energy. In the case of cars, most commonly, that is heat.
If you are using the % method, doubling the horsepower of an engine should results in doubling the heat (in the gearbox, the diff, the drive shafts, the CV joints etc). But a quick check with the pyrometer shows that to be complete rubbish.
What we have found in the engine dyno versus roller dyno is a 2wd Skyline loses (transforms actually) around 60 kw and a 4wd around 80 kw. A hub dyno is around 20 kw less, as they have no rollers.
Totaly off subject, so let's get back to the turbo comparison............
As far as I ma concerned all the aftermarket turbos in that comparison are too big for a 2.6 litre engine. So it's not a matter of which turbo is good and which turbo is bad. They are all bad as far I am concerned.
Stick Paul's 450 rwkw 2530's on the graph and you will see what I mean.
:) cheers :P
Edited by Sydneykid
:P cheers :D
ill post a few up
BTW 2530's are ballbearing...when my rear one failed, guess what i found in my sump??....ballbearings.
ill post a few up
When we say "MORE BALLS" we mean larger ones, not a greater number of little ones :P
:D cheers :)
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
