  • Replies 142
main differences:
-Wolf3d uses a MAP sensor, Powerfc Uses the car's AFM
(some argument over which is better, however wolf can be setup to use AFM. Powerfc can't use MAP unless you get djetro version)
-Wolf3d maps have 16 load axis and rpm points every 125 rpm (so between 0 and 8000rpm, it's 16x64)
-PowerFC maps are 20x20
-wolf has wideband o2 sensor built in which is very handy for data logging and tuning (you still have to buy the sensor itself, but not the interface etc.)
Both have similar features...
Look, with aftermarket ecu's, as long as you can change fuel and timing, they all more or less do the same thing. In a lot of cases, performance from and aftermarket ecu is more dependant on the tuner. It's hard to really say one is better than the other.
To put it in perspective, anything you can do with a powerfc, you can do by remapping the stock ecu (with the exception of data logging, hand controller readouts, aux out's of course...)
Ahh well thats not true really.....with the standard ECU and a consult cable you get all the data the PFC hand controller gives you, plus data logging. And the standard ECU has better cold start and idle. But the PFC is almost as good as standard
know its bad when sydneykid says its shit
Read the post properly, Sydneykid is just saying the Wold ecu is AS shit as the Power FC when running auto's. Does not mean the Pfc is any better :)
Do a SEARCH, has been discussed multiple times, especially between Paul and myself ;)
I have used the Wolf3D for years, and would not consider using a PowerFC as i believe, through my experience, that the Wolf has more features, tunability and engine safety. At the end of the day it is only as good as your tunner and there is alot of tunners making the Wolf look bad :D
actually the wolf has
+ pin code lock
the powerfc has
+ knock sensor support
so the feature set is even. each has their own advantage and disadvantage
both have airtemp support and correction
^ yes you can use consult i have an interface that i use for exactly that. I was just being general! i don't think that really changes the argument in any case.
One of the features that is very useful on powerfc's are the knock sensor. I have pondered if there is a way to build something similar using the stock knock sensor...
wolf3d has some pretty neat closed loop control options actually. I was just reading through the manual the other day. I'm not sure if powerfc has this, but i know it does use closed loop for fuel economy when cruising.
wolf3d also has a builtin turbo timer, can support different load sensors (eg. afm/map/tps etc.) and support for a secondary load sensor. The idle control settings has more stuff on wolf by the looks of things
they have similar features, but the wolf unit seems to have more settings for each thing (eg. idle control, boost control, closed loop etc.), and if you're like me and like to tweak things i'd find it an advantage. But it also would mean they are harder to setup.
IF you are getting a workshop to tune it for you, find a workshop you are comfortable with, and see what ECU's they tune, and recommend. There is no point going Wolf3d v4 if there are no good workshops nearby that tune them.
There are enough bad tuning workshops I know of, that would make me very particular when choosing a tuner that I can trust.
this may appear to be a little off topic, but....
after reading HPI and thier build up of the r32 4 door, they used a wolf ecu and said that the r32 and r33 PNP ecu's were the same... they even included a photo of the sticker on the ecu saying "r32/33gtst"... now, would i be correct in saying that an r33 pfc would work on an r32?
just curious cause i wanna buy an ecu for my r32 but don't want to rewire and don't want to spend shitloads on an AP engineered pfc...
So if you paid half the price of the known quantity (PFC) and it ran half as well with poor consumption are you really better off ?
Gary maybe you can tell me why there is resistance to using Hotwire Mass Air Sensors because I can't see any great disadvantage . Provided the bloody thing passes the air whats the issue ?
Cheers ...
SydneyKid; when you say that absolutely no ECU out there can cater for the Nissan Auto; how many ECUs are we talking about?
I'm about to install and tune a HKS F-CON unit into my car and they have advertised it as being suitable for the automatics. It has features which controls the ignition changes during a gear shift... I've talked extensively with the tuner and they are 100% confident that it will not fail.
Not only that, the features on the F-CON are from my understanding top-level; also coming from HKS I don't think that they would falsely advertise something like that.
Have you had any experience with the F-CON (V-PRO latest version 3.24 to be exact)?
Not being smart or anything, just trying to get a few more opinions as I've done a lot of reading on the unit and 100% of the feedback on the unit is positive so far.
the PowerFC FAQ in my sig states how to use the R33 PFC on the RB20 or even RB26 PFC
Paul; translate the page into English and go down to the bottom... there is a section (yellow icon I think) that states the unit's automatic capabilities - this has been confirmed by a HKS dealer and people overseas who have used it effectively on autos.
Now I'm confused; about to spend big big $$$ on getting this setup put in and tuned!
speak to bd4s in sydney. They are basically the only workshop that has the software and hardware to tune FCon's in Australia, and i've spoken to them on the phone about tuning, and I got a very good impression from the conversation I had (they were able to answer all my questions and were very helpful). They should be able to tell you how they run on automatics. I assume you've already spoken to them though!
Apart from limited availability, they are fantastic ecu's. Much better than powerfc, wolf3d.
They have a really cool feature which automatically set's AFR's (it reads wideband o2 sensor input and automatically adjust fuel map to get a specific afr), 32x32 maps and a crapload of other features. In Japan they are very highly regarded. The main disadvantage is the software and hardware to tune is only available to certified hks dealers, so you can't tune them yourselves!
i found this comparision between apexi powerfc and hks fcon pro from
http://www.gtr.co.uk/forum/upload/showthre...?t=37497&page=2
worth a read, Just keep in mind in most states, you can't get them tuned...
I have decided to write this article as an introduction into the comparisons between
two well known aftermarket engine management systems. I have decided to do this
to educate a few people, offer an opportuinity for comparisons to be sought, and decisions
to be made, particularly helpful to members of the forum who own modified Japanese sports cars.
The two different ECUs that I would like to compare are 2 of the most popular aftermarket ECU's
for modified Japanese Sports Cars.
HKS F-Con V Pro
Apexi Power FC
The necessity for optimum control over a vehicle's engine is heightened as
a car's engine is modified and transformed beyond intentions and parameters set by manufacturers
and controlled by the stock Engine Control Unit. At clubman levels, where the investments into engine
modification and aftermarket upgraded engine components are high, the particular need for
precise control is paramount into both longetivity of the engine, and ability for the user to
gain full advantage of the investment he/she has made.
The requirements of an aftermarket ECU are that it must enable the user to adjust and alter the fuelling of the engine,
the ignition timing of the engine, control over auxiliary engine functions, to record and monitor the engine's activity,
to enable interaction between the user and the ECU, and incorporate safety systems and fail safes to ensure against
engine damage.
The following is a comparative analysis of each of the aftermarket ECUs I have chosen to study.
ECM Type
(A description)
HKS F-Con V Pro:
A fully featured stand alone engine management system incorporating a "piggy-back" fuel computer interface.
- Utilises Factory ECU
Apexi Power FC:
A complete stand alone total engine management system
- Replaces Factory ECU
Resolution of Adjustability
(What levels can user adjust main fuel/ignition points to)
HKS F-Con V Pro:
32x32 Fuelling & Ignition Point Adjustment
User defined selection range
Apexi Power FC:
20x20 Fuelling & Ignition Point Adjustment
5x5 map sections
Ability to control drive by wire?
HKS F-Con V Pro : Yes
Apexi Power FC: No
Engine Monitoring System
(What can the ECM monitor?)
HKS F-Con V Pro.
- Complete total engine monitoring via software
- Parameter Limts / Warning Functions user defined for any variable.
- Datalogging Function enables user to record and re-run data accumulated through all of car's sensors over defined period of time.
Apexi Power FC.
- 10 monitored parameters displayed via commander
- Engine RPM
- Ignition Timing
- Vehicle Speed
- Air Flow Voltage (Pressure Sensor Voltage)
- Injector Duty Cycle
- Boost
- Knocking Level
- Battery Voltage
- Intake Air Temp
- Water Temp
Functions
HKS F-Con V Pro.
- Total Control over Car's Electronic Systems.
- Main Functions include:
- Ability to store 4 different fuel/ignition/boost maps
- Fuelling Mapping
- Ignition Mapping
- Boost Mapping
- Injection Format
- Additional Injector Control
- Nitrous Oxide Injection Control
- Launch Control
- Multiple User Defined Rev Limits
- User defined activation levels via pressure, speed, revs, temperature
- Acceleration Enrichment Correction
- Cranking Fuel Injection Control
- Water temp / fuel injection control
- Anti-Lag Control
- Leading & Trailing Ignition Control
- Water Injection Control
- Boost Ramp Control
- Auto A/F Ratio Compensator
Apexi Power FC
- Fuelling Mapping
- Ignition Mapping
- Boost Mapping (with seperate boost control unit)
- user Defined Rev Limit
- VTEC Control (on Honda Vehicles only)
- Leading & Trailing Ignition Control (on some vehicles only)
Injection Format?
(How can the ECM Control different injection formats?)
HKS F-Con V Pro.
- Batch, Sequential or Staged
Apexi Power FC
- Sequential Only.
Datalogging Function?
HKS F-Con V Pro.
- Yes
Apexi Power FC.
- No
User Interface
(How does the user access the ECM?)
HKS F-Con V Pro:
Through Software
Apexi Power FC:
Through Commander
Safety?
(How does ECM ensure engine safety and longetivity)
HKS F-Con V Pro
F-Con will calibrate entire engine mapping to suit user defined correct A/f Ratio, and will never let
engine run detrimentally lean (e.g in a case of a blocked injector)
- Warning Levels pre defined by user
- Limp Mode Activation pre defined by user
- Cut Off Activation of any ECU controlled electrical system, defined by user
- Use of aftermarket sensors to ensure more accurate readings.
- Datalogging.
- Active Parameter Display, Warning, Peak and Hold and Recording via software
Apexi Power FC
- Peak and Hold Function via Commander
- Warning Level Activation via C.E.L
Market Price in Japan
HKS F-Con V Pro : ~130,000 Yen = ~?650
Apexi Power FC : ~80,000 Yen = ~?400
Conclusion.
If you consider the requirements for an aftermarket ECM, as described in the section identifying
the aim and its role within the car, it must be decided how closely the functions offered by the
ECM meet the requirements. Levels of Engine adjustability, Levels of Car Electronic Systems Control, Safety Measures
and base functions are all to be considered in a solution to the need for total engine and electrics management, and in thus,
the superiority of the HKS F-Con V Pro ECM is clearly indicated. The F-Con's major disadvantage to the Apexi Power FC is limited to
its interface to the user, in that the interface requirements of the F-Con are a computer and computer based software which although portable to an extent,
does not meet the interface simplicity of the Apexi Power FC's handy, In-car
control device named " the Commander ".
The Ultimate System?
Neither!
For market leading Aftermarket Engine Management Systems, offering the greatest degree of engine and electronics
control, leading-edge technology and design quality, neither system is able to match the Engine Management Systems offered
by Motec. The M400,M600 or M800 currently offer the greatest levels of control and adjustment available to any
electronic management system currently on the market, and represents the pinnacle of aftermarket EMS.
Interface remains as in the case of the HKS F-Con, in that the Motec EMS is configured via a computer interface.
sorry if this is a bit off-topic... and the big post...
i'd also like to add, that with hks pro dealers who tune fcon's, they have to go through a very vigerous process to get the software, which i think involves going to japan and being taught how to tune from the experts. So you are pretty much gauranteed that your tuner will be very capable if they are a hks pro dealer. Unlike some tuning shops i've seen who tune powerfc's, and they really don't know what they are doing.
Edited by MerlinTheHapyPig
OK sorry my bad about the website reference... takes a little bit of detective work. Basically the V-PRO is an uprated version of the IS. The V-PRO contains all the functions of the IS and most of them are enhanced for race/professional usage.
On the V-PRO page it states as one feature:
"AT shift and revision"
* doesn't leave much in terms of detail ehh?
However, looking at the IS page, a description is given:
"In the A/T car, at the time of high load because the knocking which is easy to occur at the time of shift rise or kick down is not caused, engine rpm fluctuation and throttle opening are designated as condition and ignition retarded angle revision of fixed time is done."
Yes, I have talked to Tom @ BD4s extensively about this as well as others who have the units in their cars. Merlin, you are right about the limitations (tuning availability) which is why most of my enquiries went overseas to users who have been running the gear for ages (predominantly UK and Asia).
Trying to stay positive about it... we'll see after next Thursday ;)
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
