well the modifications have kinda begun... got myself a new front bar and put some different rims on.
Rims came with the car from Japan, but couldn't switch em until after rego.. not that VicRoads would know, but i thought i'd play by the book...
I think the different front bar is a vast improvement, considering i had a stock one as i sold my Nismo/Altia one to Dale ;)
what ya think? not 100% what to do from here with it....
On a little side note, i believe i am the only person in the entire country to have this front bar :dry:
https://www.sau.com.au/forums/topic/122202-my-r34-has-a-new-face-and-feet/
  • Replies 79
yep, got my year 1 scissors out and chopped the lip off.
i want to lower it but the front bar has next to no clearance already! :P i need 18's or i need to be SUPER careful...
ylwgtr2 chopped the lip for me... i thought it could be done, so i gave the job to him knowing he could do it ;) which he did :dry: - yeah, whole car is up for a respray... but i don't know if i have the funds really, going to Africa in 2 weeks for a bit over a month...
Front bar is an exact GTR replica, made by East Bear (plastic injected moulded, not Fibreglass) and made to fit straight to the narrower GTT guards...
yeah, troy did mention i should make a copy of the bar... in case of breakage... no cheap ass copies of this around, so would have to get it sent direct from japan... $$$$$$$$$$ -
yeah, unfortunately i think 18's are the only way to solve the height problem...
yes, the bar isn't your $300 unpainted fibreglass dodge copy - i'll just say $1k+, not the sort of thing i want to be destroying any time soon...
hey dan, i'm not sure it troy(ylwgtr2) would want to do this again! you'd have to find someone up ur way how could chop, weld, make it look nice... oh, you need a GTR bracket/support bar thingy too... i'm currently borrowing Troy's ;)
what u reckon i could get for the rims? genunine Advan Model 5's, nice and light... Advan Neova tyres.. 235/255 front/back
EDIT: satanic: yeah pictures are shite... late afternoon, when i install the CS2 suite i have lying around somewhere, i'll try a fix it... you're right, can't quite see all the lines/curves, etc...
ok ok, my photograhy skills suck, i know i know ;) - thaka mate, some help!? :dry:
look at Dezz's avatar...
the bonnet is now the same as a GTR bonnet, the front bar is the same as a GTR front bar... the 2 together..... :P you get the idea..
man, don't make me put a GTR badge in the grille! :yes:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
