  • Replies 79
id put the spoiler back on the rear, change the side mirrors, change the skirts to something a bit more even with the front bar :rofl:
looking nice :rofl:
what you been smoking akeenan :D have u seen the old spoiler?
what you mean Jar, spoiler "ftw"?
bugger, i wouldn't have minded some for half price, if they were the same - yeah, def need 18's.
yeah very similar to GT4's but without the $$$, like $1050 a rim for 18's? or was that $700... something huge... i would love the GT4's from the ZTune (black, shadow chrome, whatever), but too pricey... and i don't think you quite get the effect without them being on a GTR - where as these rims have that inward spoke look already...
yeah apparently $1050 per rim..ridiculous coz i want them too lol
let me know how you go with the bee-r ones in 18"...what prices etc and where from
"ftw" means for the win, and is quite possibly the most annoying and lame abbreviation, used WAY too much on this site...ban it i say
prices on the Bee-Rs in 18s are actually quite reasonable... even after the importer tacks there bit onto it.
When i was looking at importing a set Bee-R had a special on and it worked out to just over 1800 landed.
Nice front bar.
But the whole car looks a bit uneven now, you might need some different skirts or rear bar as it looks very nose heavy.
And putting on 18's will probably not solve your height issue as your 18's will have a very similar rolling diameter to your 17's.
Even up the rest of the car with the front bar, and itll be sweet!
yeah, i'm trying to sus some skirts/rear bars out but haven't heard back as yet... too be honest i wouldn't even know what else is really out there... not a fan of those bomex type skirts/rear bar...
well 18's are going to make it sit a little higher, fill the guards up a bit more, which then means i can lower it down a little back to where it is now (which is ok, don't really scrape if i attack some steep things at an angle)
so the whole combo of a little higher, a little more filling out of guards and then being able to lower it a little should make enough of a difference i'm guessing..
respray it bayside blue... go on... do it!
frontend conversion looks hot as. well done... well if it's had troy's hands on it you can't expect anything else.
i would love to do it TV2... but hmm... dunno... that means engine out... more $$ - i'm grown to like black... looks pretty tough and hasn't been the nightmare cleaning job that some ppl make out
if i was going to do anything different, it would be the Lambo fiery orange/pearl colour with a carbon bonnet... but i'm going to struggle to pay for any respray and i've been told a repsray to the same colour is easier/cheaper? yes no?
no troy won't be doing the respray. I need to metal weld the spoiler holes on the rear quarters, and also the annoying rust spot under the centre brake light that so many 34's have... that's extra, quoted $1500 only just to spray/weld rear quarters and boot (rust spot)... guy said, for another $1500, he'd do the whole car...
well, who's going to hook me up with a good deal for a TV2 then? :D:rofl:
well, who's going to hook me up with a good deal for a TV2 then? :blink::)
go LX0
or, the champagne metallic on the r34 gtr
Whats everyone going on about bigger wheels filling the gaurds more and giving it more clearence? how does that work? Since when you go up a wheel size you reduce the profile n the tyre to keep the same rolling diamater, which means your car ends up the same height and same gap between the tyre and the guard... you just have more rim and less tyre.........
or am i missing something here?
ps, R34 GTR fronts look so tough!
I'd also be worried about a 3k paintjob... i've never had a full respray but for a proper one they have to remove the windows/lights etc.. which i would of thought would cost a lot more than 3k......
Ahhhhh so that was YOUR car I saw there. Interesting.
Bar is good but you will never be able to lower the car, I saw how low it sat stock, you'd loose it first curb or speed bump you mount!
I saw the work on the bonent, Troy did a good job. Should look good finished.
Nice work Chinny,
I'm with Ferni, bigger wheels will not work for clearance because you are limited by the suspension and guards on your rolling diameter.
Air bag it!
Best of both worlds.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
