Hmm so tomorrow my cars going in to have a walbro installed because according to the guy who checked it out its either that (causing misfires stuttering) or the timing belt is mis-aligned by a tooth. (am paying $270 for the pump and 70 for installation which sucks some serious ass because the guy i was gonna get the pump kit off, on this site sells them for $170)
Any way tonight driving somewhere gave it a little gas, watched it die out harsh at about 3k and start back firing huge, and had no power by 4krpm etc, kept doing it then i ended up at my mates house. Had the car running turned on lights heater, noticed the HICAS light flickering then listened and noticed a loud knocking sound coming from somewhere under the bottom (sounds down the bottom end of the bay) Is it a frigged alternator that could be doing this?
When i dont have any lights or anything on it doesnt happen.. Coil packs can cause the problems im having (missfiring at high revs stuttering at 3k) Would a frigged alternator cause my coil packs to not be getting the power they desire to run well and therefore be the cause of my troubles? (side note this only happened tonight and i have installed a sub into my car and amp only a week ago, so its a big coincidence)
(Installed the FMIC and it got alot worse then replaced the fuel filter and its gotten a crapload worse since replacing that so idunknow)
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/122430-screwed-alternator/
got a multimeter to test the voltage on the battery?
should be 13.8V or close to that..
if its well below that and it stays low even when revving it up it could be a loose belt or an issue with the alternator
neighbours arent gonna appreciate the noise but meh, brb testing
K tested it idling for a minute with headlights on stereo pumping demisters windscreen wipers heater cabin lights all on full, dropd from 12.35 - 12.2 (was at 12.38 when off).. Strange, hate problems that occur on and off. Break and stay broken demit. Will try drive it to mechanics tomorow regardless of whether that sound happens or not, thx. Cant believe how difficult it is to diagnose that damn missfiring at high rpm thing.. crazyness
^^^ That is low, and would normally show signs of a stuffed alternator, but:
- That sort of voltage is the normal voltage you should get when starting up with just the battery and no alternator. So would tend to say to me that your alternator has been working previously unless you had the battery on charge.
- Your battery light would normally come on if the alternator is not charging the battery.
I suspect your sound system must be using too many resources. Don't know much about sound systems, so some audio fellows may need to help you out on this.
Just a sidenote: Could be that your battery is on the way out. Dosen't normally take too much to start the car, however you could notice it like you have when you are asking a lot of it at the same time.
Edited by Thunderbolt
nah seems pretty quick to crank n jump over still. Its strange then that the battery light doesnt come on. Did it this morning in traffic, heater + lights + stereo on low = HICAS light flashing == loud knocking noise. If the engine wasn't getting the spark it needed i guess this could cause the knocking? Sucks that its already at the mechanics because this sort of convinces me that my cars been having spark issues not fuel pump related problems, oh well
mm running 10 psi now, since it started frigging up (didnt help though unfortunately), my plugs are the iridium tipped ones everyone uses for these (got the serials off this site) NGK's i think cant quite remember what i chucked in.
Seems that theres no mechanics around who will be able to give me a straight out affirmitive answer to my problem. Can see some huge bills coming :thumbsup:
i would say almost 100% it's the alt. you really need to test it. it should be putting out 13.8V. I had this same problem in my 32 GTST. hicas started playing up (light coming on) powersteering sometimes went heavy. And a loud banging noise (i think solenoid opening and closing), and eventually it just killed the battery. put a charged one in to get car home and it killed that too. rebuilt the alternator and all these problems went away :whistling:
eyyy, just replaced my original ones though (plugs, 3 weeks ago), things cost me like $125 @ trade price, not to keen on re-replacing them, didnt seem to make any difference to my problems when i put the new ones in.
Thats sounds alot like it baron, dunno how much an alternator is worth on these things, probably 500 installed or some crazy figure like that, damn imports. I'll leave off doing it a bit as people dont seem to think its the cause of my other problems (stuttering, no power, louding backfiring noises)
thx
thx
Nissans are extremely susceptible to voltages. Bad voltage equates to bad running.
Get the alternator tested; if it's a dud, replace it.
FYI - I had my alternator overhauled recently (for 180sx) including new brushes, bearings and servicing and a repair to a burnt connection (which was causing no charge to battery - PFC was reading as low as 11volts at one stage). Lets just say it cost about half of the price you mentioned.
BTW: With these problems, I had few driveability issues, although I was babying it around a bit. The Walbro was making different humming noises than usual, but otherwise no unusual noises or other such problems.
my alternator died on my ceffiro two weeks ago, the previous owner put in a dodgy underpowered rebuilt one. Anyway a new one would of cost $460 dollars
Similar price to rebuild the one melted.
Got a second hand one going in today.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
