Hi all
I know of a brand that makes sway bars in the following sizes for a R34 GTT
F 31.8mm and R 27.2mm
Now Nismo make em at F 27.2 and R 23.0
and SK's group buy is at F 24 and R 21
Now should I go for the thicker one? it seems like Whiteline gear are the smallest sway bars, Nismo being a step above, and the other brand even bigger.
What do you guys think? are there any downsides to thicker sway bars? (I dont think so but I may be wrong)
Thanks
https://www.sau.com.au/forums/topic/122547-anti-roll-sway-bar-thickness/
The whiteline bars are blade adjustable, with numerous holes in them to increase the amount of anti sway or decrease. Both front and back are like that. Are the nismo ones adjustable? I know a mate of mine got some cusco ones and they are just plain ole swaybars, but slightly thicker in diameter.
The traction part is debatable, cause it depends on how it is setup:)
Mike has it in one.
These would be fine on a super smooth track using slicks, but if you want to drive daily get used to the idea of driving real easy through corners in the wet or over bumps, unless you like the idea of becoming part of the scenery or looking back at oncoming traffic.
I have a 30mm rear bar for my Lynx which transforms the handling, but I've had to reinforce the mounting locations due to the stresses applied as it tears standard mounts apart.
Reading an article from about 18 months ago with regards to touring cars. Two drivers from the same team were lapping about the same, qualified withing poofteenths of one another, and the data showed them having similar consistancy throughout the race...traffic permitting.
One had huge swaybars and soft springs, other had hard springs and bugger all bar. So different strokes for different folks. The chassis were not identicla and its posible one chassis liked one setup more then the other...but odds are it was driver preference.
My thoughts, if you rely too much on bars to control body roll and run too soft a spring, then surely you will have trouble controlling the pitching of the car under brakes and acceleration?!?!?!
Can you put too much bar on a car? I believe you can. Is 31.8mm ec too big for a daily driven car? I dont know. Give it a try, but gut feel is they would be too bigv (Thats assumign that all these cars are solid)
In the race car they can use brake biasing and other adjustments to account for the pitching, but on slicks it makes a big difference. On road you will be having problems unless you walk in to a good suspension place and let them do a complete and costly setup.
Roll / sway bars have nothing whatsoever to do with traction.
Roll bars stop body roll through corners. As a rule-of-thumb, stiffer front roll bars increase UNDERSTEER, stiffer rear roll bars increase OVERSTEER.
The stiffness of a roll bar is also proportional to the diameter of metal in the bar. So a 27 mm HOLLOW bar may be lighter (less stiff) than a 24 mm solid bar. I found this when I replaced a 25mm (hollow) rear bar on my GTS4 with a 24mm SOLID bar.
You need to check all the properties of the bars in question, and decide what you want the bar to do, before it can be determined which bar is best. That said, Whiteline has done a heap of work working out the best combo of bars (and other suspension components) for these cars under Australian conditions.
Blind elk
why they have nothing whatsoever to do with traction
but
stiffer front roll bars increase UNDERSTEER, stiffer rear roll bars increase OVERSTEER ?
stiffer front - less traction in the front = UNDERSTEER
stiffer rear - less traction at the rear - OVERSTEER
:P ???
Actually it's true by the normal definitions in racing.
Traction is a straight line term. Anti-roll bars don't help in a straight line.
Grip is a cornering term. Anti-roll bars contribute to the overall balance of a cars grip when cornering.
The stiffness of a bar is not however proportional to the diameter but to the diameter to the fourth power, so the 27.1mm solid rear bar will be 2.81 times stiffer then the 21mm bar rather than a straight 1.2 times stiffer.
I can bore you with even further detail, but unless you are a race engineer it won't make much difference. Don't buy them unless you are sticking to the race track.
The question has been more than answered.
That's ok. Most English as a first language guys have problems with the terminology.
BTW below you can see the amount of roll on a GTR33 with Whiteline blade adjustable bars set to full soft front and rear. I was throwing the car in pretty hard and you can see the outside tyres are in full contact with the tarmac pumped to 40psiF/38psiR. You won't need any more than the Whitelines.
Hi all
Thanks
Hi, let's clear up a the size issue.
1. The Whiteline bars in the Group Buy are selected (by me) to suite that application, they are for a road car with the occasional circuit and drag use. Plus they are matched to the Whiteline spring and Bilstein shock rates.
2. If you have a road car with lots of circuit use, then we would go to the next size up ie; 27 mm front 24 mm rear, both adjustable. This means I can still use the matched to the Whiteline spring and Bilstein shock rates and the car is not uncomfortable to use on the road.
3. The Whiteline adjustable stabiliser bars have bladed ends on the arms, to allow for the adjustment holes. This blading effectively stiffens up the bar as it removes the flex that you get in a round bar. On the Group Buy's softest setting a 24 mm adjustable bar is the same rate as a 24 mm fixed rate bar, and then there are 4 settings siffer than that. So the diameter alone doesn't tell you the whole story.
4. A 27 mm adjustable bar on the full stiffness setting is almost equivalent to a 30 mm fixed rate bar.
So, it's not how thick it is, but how you use it (where have a I heard that before?)
:P cheers ;)
Also, there is a world of difference in stiffness between hollow and solid bars too.
Actually there's surprisingly little, as it's the outer "skin" of a solid bar, in torsion, that does most of the torsional resistance. I have the maths for it somewhere.
I have 33 Gts-T. I bought the car and it had a solid 31mm bar on the front (brand unknown) Rear was standard. The car understeered BADLY! Got the whiteline adjustable and set it to medium and its so much better in handling. the car is used for local track/events and the times now are a hell of a lot better. I will adjust it to harder later to see what difference that makes but at the moment while its feeling good and other things are being done to the car, i aint going to alter it. (Dont like to change to much suspension at once).
Regards
R Dirty 3
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
