Further to this I've now been informed that the date for this will be Dec 2nd and 3rd and will involve a minimum of 4 runs per day and will cost aorund $1K to enter.
Will be Dutton Rally regs too - so LS2, normal sprint track regs (no cage etc) and no navigator.
  • Replies 63
yeah it will be super quick. Neil did the buladelah climb which was pretty wide, the old pac is even wider....
and $1k is cheap for an event from the dutton guys :)
Agree it will be quick If you havent done a Tarmac Rally/Road event this will intimidate much more than Race track big balls + wide road = high speeds + big trees = yeha
Wanna know more about "Race to the Pie" ??
http://www.performanceforums.com/forums/sh....php?t=67204771
Guys,
I am allowed to release the following "rumors"
(they are still "rumors" as there are still a few loose ends to finalise - but "they shouldn't be a problem" I was told..)
website coming soon.... (www.racetothepie.com)
Make of them what you will... (and spread the word I was told)
It starts near a bridge and ends near a pie shop
It is on the weekend of Sat 2nd / Sun 3rd December 2006
It's 4.5 Kilometres in length
There will be a limit of 150 cars
It will NOT require a roll cage, and hence NOT needing full CAMS regs in regards to vehicle preparation.. - Obviously there will be other regs that you have to abide by - Fire Extinguisher, Helmet, Clothing, Road Registered and must pass scruitineering etc...
Entry will be under $1,000 per driver (how far under is yet to be finalised)
There will be opportunity for Driver AND co driver runs in the same car.
Vehicles will start at 30 Sec intervals
It is expected that you will get 6-8 runs each per day
As I said, these are the only "rumors" I can release at this stage
So... This looks like the opportunity for those of you who say you are quick on the "insert road here" to prove it.....
What is that saying again...???
When the Flag drops.....
i would be in like flyn but considering i can run 5 track days for under a grand I think common sense tells me sit this one out. :)
So how many track days and cases of piss do i get for the $2200 Dutton Vic entry? Damn the torch that was passed to me and Jamezilla, its now our job to show how ordinary Snowman and Scotsman are :)
  • 4 weeks later...
  • 3 weeks later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
