Hey Guys,
Just a question for anyone with an R33 GTR. Where did you guys get your Oxygen sensors from if you have replaced them, and how much did you pay for them??
I cant see the value in buying them from nissan for a total of $450. I just want some universal ones that i will adapt my old plugs to, but havent had any luck finding some over the last 2 weeks!
The specs are: 18mm thread, Titania Sensor, Three Wire, voltage range of 0 to 1 volts.
As you can see from the pic, my car is a 32 GTR, but i am running 33 dumps, which have the larger thread. So alternatively, if anyone knows where to get the bungs from to run the smaller 12mm thread 02 sensors from that would be great. (or even if you know of where to get them fabricated in Brisbane).
Thanks Guys, im beginning to get desperate!! :D
SLVR32GTR
Edited by SLVR32GTR
https://www.sau.com.au/forums/topic/123107-gtr-02-sensor-cheap-alternative/
hey man, im in the same boat.
i asked this question a little while ago, but didnt get any answeres!
hopefully someone can help us!
steve
I know what you mean, i have been asking all of the reputable performance shops around Brisbane, also NGK and what not, and all i have recieved back is, "ahh sorry we dont have them or even know where to get them!"
Gets a tad annoying considering i need them in order to do my long awaited turbo conversion!
Surely someone on here has a 33 GTR and has changed there 02 sensors!
G'day blokes,
Changed my GTR 33 sensors 2 months ago. Cost me $339 for the pair from Nissan(genuine at trade price). I went through the long drawn out process of looking, phoning and eventually talking to technical specialists at most aftrmarket places for replacements. No luck, not made for direct fittment.
G'day blokes,
Hehe,
I thought that this would be the response. I suppose i am just suprised that nissan succeeded in making absolutely every part for a GTR the hardest and most expensive parts to come by! :D hehe
Ohh well, i suppose $339 isnt toooo bad.
Thanks mate.
Oh and for the record, i even went as far as contacting specialised dealers in NZ and the UK with still no luck!! Unbelievable.
If the GTR uses normal Zirconia type Oxygen Sensors (like the RB20/25), which im sure they would, then just buy a universal sensor with 18x1.5mm thread (standard O2 sensor thread) and you cut the connector and wire from the old sensor and crimp it onto the new universal sensor. (it will come with the crimp terminals and everything)
Universal sensors are around $40 - $80 at most.
You can't solder Oxygen sensor wiring as its stainless. (Thats why they supply crimp connectors with the sensor)
Thats the problem though. GTR's (32 and 33 anyway) use titania sensors that are very hard to come accross. Basically 32 O2 sensors (12mm thread) can be bought through NGK, and nissan, but 33 (18mm thread) i have only found through nissan so far.
Talking to Sydneykid, he mentioned that a generic bosch lambda sensor should work for this application and only cost around $80. I have not researched this yet to verify though, so dont take it as gospel. These sensors are available through places like Repco.
Tony
VL Commodore and R31 use Titania 02 sensors that have the smaller thread size, have you looked into them at all?
Titaniam sensors are smaller due to their design. They are actually not a self generating sensor like the zirconum type, but a voltage reference sensor.
What this means is that instead of self generating a 0-1V output, it uses a resistor that changes resistance with the air/fuel ratio to give a 0-1V output. It uses the power from the heater 12v supply.
You can interchange them as them as they both give a 0-1V output. The only thing to note is that all Zirconia type sensors are the larger 18mm thread and Titania types are typically the smaller thread.
I have in the past, removed the bung from the exhaust manifold/dump pipe with the smaller thread for titania sensor and got a bung from like R33 dumps that have the 18mm bung and used the cheaper Zirconia type sensors on RB30 engines that originally used the Titania type sensor.
Do the GTR dumps have a large 24mm bung that is screwed into the dumps with the O2 sensor hole inside the bung? If so the bungs just unscrew.
  • 1 month later...
  • 1 year later...
Site sponsor Kudos does them HERE, but for a 32 GTR its still ~$325. FWIW R31/VL sensors are <$100.... I also need some, and i'll put them in when i install turbos and xforce dumps (which also come with reducers).
Does anyone know if all titania o2 sensors are electrically the same WRT sensor output? (and therefore theoretically adapable?)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
