Jackets... Get Your Supercool Sau Vic Jackets...
Will (and anyone that wants to know) the reason we changed the jacket design (from the jacket where the vest zips in) was after getting the original sample we discovered that the piping on the sleeves on the other jackets was only 6cm appart. This meant that the logo's on the arms would be overlapping the piping and would look stupid. The new design allows the logo's to fit in between the piping. Plus the jackets and vests we actually got are nicer than the original ones anyways.
Fair enough, they look great, overlapping would have looked very wrong. Good work peoples :( .
I'll just have to stop being lazy and put the two bits on seperately :P
I could really have made something of my life if I wasn't so bone idle.
  • Replies 279
Posted Images
Reminder for anyone wanting their jackets in Shepparton on the weekend to let me know before tomorrow arvo.
So far...
Dezz - M
Haley - S and XS girls vest
Jackie - S and S girls vest
Magnum PI (Justin) - M (to pay on collection)
Dark - L
Al - XXL
Gareth - XL
Come and see me to collect. I'll be there on Friday at the convoy meet.
Thanks everyone,
I like my Jacket so much it makes me want to dust my Skyline off and drive it around stopping randomly to get out and pose like a wanker.
Fully sik
Let me know if we can get little ones for kids!
I have to give my thumbs up to the warmth of the jackets, coping with chasing cattle this morning at 2 am on a quad bike in major fog.
I wish i was having that much fun with mine. I think I'll wear it tm.
Oh :D Bec look forward to another event in the future/.
No kiddie sizes yet sorry.
Perhaps some kids t-shirts for summer... My Dad's car can beat up your Dad's car
What about "My Mum's car can beat my Dad's car"
I would order 2 of those!!!! >_<
and save them for when I actually get an R34. :mad:
OK - I have not heard from the below people re their jackets.
Daz (spdkls) - XL
Skybee (Ben) - L
Crack (craig) - XL
Yug - XL
Shivam - S
Graeme (gdogzgtr) - M
If you guys are still after your jackets, please PM me with how you want to pay for/collect your jackets.
Also I have some extra jackets available in the below sizes:
M - 5
XL - 4
XXL - 2
If anyone else is after a jacket, I will have them at the meeting tomorrow night, or PM me if you are interested and we can work it out.
Also should be noted that the prices are:
Members - $120
Non-members - $160
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
