I vote new thread to discuss where evryone fits into the stagea section family, to keep this thread relativey on topic.....?
Topic Spit Successfully, woo hoo first timer! :ermm:
New Stagea family tree thread is here:
http://www.skylinesaustralia.com/forums/in...howtopic=123910
  • Like 1
Here is my lil beast. big beast. or whatever. couple of shots, need to get out somewhere and try and take some artistic shots, but it always looks wierd cos the front bar sits a lot lower than the rest of the car. like a damn plough.
how do you put the pictures directly into the post? as opposed to having thumbnails?
nice rides guys, and marc2 yours looks mint in white with those wheels/kit, just need a lower front lip to match the sidskirts hieght and it will be awesome :)
It was a little lower, but I have raised it - am a little shy of 'gutter rash'.
Hey what tha!!!!! I didnt even know those photos were taken......
I feel so violated!!!!! :laugh:
ummmm....yeah you know that day on Saturday.....think its called a birthday----took them then :D:nyaanyaa:
it's also not a stagea. looks like someone put the front end on something else, looks at the door windows, and the back isn't square enough
you are right!! Its cut and paste job. look at the difference in paint color at the front fender
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
