looks wild mate... i want that bonnet... anyone know what it is an where i can get one...
anyone have any idea what kit / bonnet i have ? i'd also love to know!...........the guy in JP did a good job :woot:
( left some photos in the car too :) )
100% Dolphin. Should be painted CF too.
Edited by iamhe77
Says that bonnet is discontinued....
u can obviously read japanese??
from what i can tell the previous owner has spent alot of money on it. :P
makes the price i paid for it even better!
i think i'm going to be making a list of all the things i can see is modified / non stock.
might need some help as i'm pretty new to Stagea's!
if you can see inside your rear bar, should have a 'tattoo' that says dolphin ... mine does :thumbsup:
my car is going to look just like yours but white, the hood is going black though, for that look :)
look hot man, get alot of looks in it ?
if you can see inside your rear bar, should have a 'tattoo' that says dolphin ... mine does :(
my car is going to look just like yours but white, the hood is going black though, for that look :D
yeah i get alot of people looking at it.... bit of a change from driving around in something that gets 0 looks per drive.
:D
will have to check for the tattoo on the weekend :) my underground parking spot has minimal light and room :( !!
Edited by atomaly
  • 1 month later...
Finally some days without rain so gave her a wash and took some pics.
Takero front bar, autech sidies and rear bar, unsure what type of wing (if you know what it is tell me please), dolphin grill and unkown eyelids.
GTR wheels, r33 front brakes and r34 rears, bilsteins allround with selby sway bars.
Engine is stock with front mount and turbo back exhaust.
Next on the list will be getting front windows tinted to match rear windows, and shift kit for the auto box.
