  • 4 weeks later...
  • 1 month later...
There's no doubting some tender love and care has gone into this ride. Not to mention some serious hard earned ....
Soz for picking a fault, but when you eye something this nice, any spot or blemish stands out like dogs balls.
I'm sure in time you will grab something nice to complement the rims and complete the package.
Looking good Darrin.. mine goes for paint real soon... what the go with your roof rail holes?
Bloody roof rails. We have been waiting for the replacements ones for over 7 months
The ones on there are the factory roof strips painted out with the rails removed, hence the 3 holes
:) At least he has the rail trims! Check out my car next to Darrin's: all I have is surface rust and race tape. Damnit: now I've started on the "roof rail rant" again! :banana:
less whining, more interior pics
Looks good samkoek!
Darrin - Just looking at your Stag again, have you ever considered fitting a set of Bride/Recaro's? Would finish the look off nicely!!!
Also, for those who have painted their standard roof strips, is that going to be suseptable to rust or anything?
Looks good samkoek!
Yep, I have 2 pairs. Brand new pair of red recaro Milliniums and a vgc pair of Mits Evo 8 factory recaro's
No rust issues painting the strips as they are s/steel cover in plastic/rubber stuff. You still have the holes to fix thuo.
The blue one above has a Masa rear bar and sides, same as my car. Wing not sure.
hi guys, thanks for your comment, i am not sure what front bar it is, but is look same as the RB26 stagea one i guess, and the side and rear is MASA i guess too. i bought car like that. i like the colour, it stand out. everywhere i go and the people always look at my car , hehehe. Make me very uncomtable..shy..
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
