Hi Guys,
Read an interesting article by APC regarding the use of 3rd gear when producing a dyno report. My last couple of tunes by Bris Tuning have been done in 3rd gear which is frustrating to say the least. When I asked why they used 3rd gear they said it was too much strain on the car and equipment (bullshit) but the result would be the same!!dyno_difference_in_3rd___4th_gear.pdf
Edited by stealth
https://www.sau.com.au/forums/topic/123830-dyno-results-in-3rd-or-4th-gear/
  • Replies 44
Posted Images
Hi Guys,
Dyno runs should be in any gear closest to 1.1 ratio such as 4th in a skyline.5th Gear is overdrive.
Varying on the dyno,The run should never reach over 240 Kms an hour otherwise on a dyno dynamics dyno it hits the electric break and slows the car down,In this case you will need to do the run in 3rd gear. If you have it on shootout mode the ramp rate is automatically set when you chose Shoot 6F,The Gear and tyre Pressures should be entered as well as temperatures of the day.Inlet air temps will also show to prove that the sensor isnt near the extractor manifold reading hi inlet temps giving hi hp readings.
If you load the car in 3rd instead of 4th there will be a little change in hp as it will ramp quicker but nothing more then 40hp just depending. I tested this on my dyno dynamics dyno and only got 5 hp difference
Its good to hear another side of the story.. as always there are so many different solutions for the same result. Its hard for the novice to know who to believe.
Thanks for the input
In 3rd there is generally less load, same as less in 2nd and in 1st
turbo cars often make more power with a higher load as they can build more boost (there is another thread on here about it). so in 3rd gear on the same ramp rate it wouldn't have as much power difference as it would on the highest ramp rate.
what about changing diff gear ratios?
I have tryed this on my car personally and found that there is very little power difference, even when we changed ramp rates from 100 to 150 only a few kW difference.
also the link isnt working for me.
Edited by GTR1993
This is exactly what I have experiened, In third it made 4rwkw less and it was consistent, we did 4 power runs alternating. :D
Sorry guys, dont know why the link isn't working - scanned an article and it has created apdf file which doesn't seem to open.. any hints?
i had my stock R33 dynoed...i was putting on an exhaust the next day, so i spent the cash to see what it was making in stock form, and planned to re dyno it once the exhaust was fitted to see the gain made.
my bog stock R33 made 182rwkw....the dyno operator proceeded to tell me that "you never know whats under tha heat shield...the dyno doesnt lie"
after explaining that its not possible for a car with a 187kw engine to make 182rwkw, i gave up as "i had no idea what magical turbo was under the heatshield on my bog stock R33"
i posted a thread about it when i realised it was ran in 3rd gear, and had mixed responses...mostly people telling me that im wrong, and that the gear doesnt make a difference.
Seems someone has deleted my thread ...dont know why
Hi stealth,
Was this a 4WD Dyno or a 2WD Dyno.?
We have the challenge of running a GTS4 AWD RB20DET car on a Dyno shortly this week, but I'd like to know of some differences between the two as well as the selected gear for the run. Car is an automatic.
Seems a grey area to me about the whole procedure.
Cheers
As already stated the reason for using lower gear is so not to overspeed the dyno, stock to mild cars should have no problems being dynod in top gear, and the same for automatics, if your car does over speed the dyno in top you usually finish top end of tune at the track, which in most cases is what has to be done anyway. usually only get 90% of tune on dyno and clean the rest on the track. as for the power readings, as long as you dyno the car the same way before and after your modifications, you will see an improvement which is what you are looking for.
Dyno run should always be done in 1:1 ratio or 4th gear.
Sometimes the run is done in third if the vehicle has a speed cut and cannot be taken right out.
So there is a difference in output between the gears. I'll put this down to load (ramp rate)... same way that full boost in first happens about the same time as the rev limiter. Load is important to turbo cars...
Theoretically, shouldn't the kW be the same, because it will register as more torque and less speed? and also, a lower gear with a higher ramp rate ('magically' matched, or course) should produce the same load on the engine, so the same amount of kW...
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
