hi guys finaly got my registration login 'first one didnt work'... no problems now though :).. so aprox 2months ago i purchased my dream car and it was all thrills, prob did 500km worth of driving that first weekend.... shortly after this things turned sour, the engine popped the dipstick out, shortly followed by the catch can filling with oil then overflowing,, basicaly 1.5lts of oil for a 10min drive,, not good. being a motor mechanic i stipped the head off as i suspected piston/piston ring failure, sure enough there it was, now the car had 69,000km on it ' came from japan origianly, priv import'..it had a gredy front mount,full trust exhaust, 300zx single turbo running 1bar, apexi air filter,blitz blow off valve all managed by a plug in garage saurus ecu, the car went nice untill all else failed,now im trying to decide what to do, rebuild to rb20?(is it worth doing) or go for a 2nd hand rb25 and bolt that in, only problem is im finding it hard to find prices for rb20 bits, and i didnt realy want to put in a 2nd hand rb25..... just thought id come here and vent my frustration, any glimmers of hope you fellas might add id be more then welcoing, thanks for your time.... dead32
https://www.sau.com.au/forums/topic/124172-unhappy-camper/
Firstly...
What made it pop... Are you still running the std fuel pump?
my guess.
Well since you know your way around a car I say a second hand RB20 for not much money will be cheap. Get a tune after you install it. Failing that I think an RB25 upgrade will do the job.
https://www.sau.com.au/forums/topic/124172-unhappy-camper/#findComment-2294257
I have been told you can bore out a RB20 safely to quite a huge degree, I am sure someone on this board will know for sure and just how much.
It would be a cheaper and easier alternative to an RB25 which is really what is needed for torque reasons.
And it of course saves you the obvious hassles of locating a used RB25 for the right money and then trying to smash it in.
https://www.sau.com.au/forums/topic/124172-unhappy-camper/#findComment-2294408
turn the RB20 into a RB24. probably only cost around the same as the 25 conversion, and best bit is you get to keep your original motor, and original engine number. trying to get your car rego'd etc with engine numbers that dont match, and an engine swap can be a bitch. not to mention insurance is higher etc etc. no one has mentioned that yet, but i think it should be a consideration.
https://www.sau.com.au/forums/topic/124172-unhappy-camper/#findComment-2294889
Another one who ignored the first rule of buying a modified turbocharged car (import or not), get the tune checked on a dyno. Graph the torque, rwkw, A/F ratios and boost, plus have the dyno operator listen for knock. The best $100 you can spend.
:D cheers :wub:
https://www.sau.com.au/forums/topic/124172-unhappy-camper/#findComment-2295184
What do you want to do with the car, how much power are you after etc etc?
A $600 wrecker RB20 will have you back on the road and provided the fueling etc is correct you will get years and years of loyal service out of it.
RB25???? Just make sure you do the sums and you knwo what it will csot you....just abotu every person that has claimed they can do it cheaply has realised its never as cheap as you first thought.
Best throw an RB25 box in with the engine, there is another $1500. Then do the timing belt, water pump etc on the replacement engine, the new talishaft, the new loom you will require with the engine and the mods to interface it into the R32. Then you have a std RB25 with unmappable ECU and a std ECU that reaks havoc when you boost up the std turbo let alone put a modified one in there.
So not all bad, but ppl say throw an RB25 in there...its not exactly a cheap option.
All up you can have an RB20 in there for $1500 including fluids, everything since you are a mechanic and can do the labour yourself
https://www.sau.com.au/forums/topic/124172-unhappy-camper/#findComment-2295636
:) cheers :w00t:
agreed! should always check tune when buying a skyline..
if it were me, i'd just slap another rb20 in (well i have a spare one in the garage), but if you can't do the mechanical work yourself, you're better off with a more permanent long-term option so you don't have to pay for labour to swap another motor if you get a dud. So perhaps consider a proper rebuild, or rb25
https://www.sau.com.au/forums/topic/124172-unhappy-camper/#findComment-2295786
$600 rb20's? hmm
the 100k servicing needs to be done anyhow.. whether its an rb20, rb25, rb26.
rb25 box, well can be left for a while with rb20 box (like mine) or buy another. An rb20 with similar power still requires an rb25 box at some point anyhow, with the tailshaft mods, etc.
Wiring mods? quite easy.. if you have the full rb25 engine loom you can work it out, direct to rb25 ecu. I'm not an auto elec, nor a mechanic, nor ever rewired a conversion. Factory engine+ factory ecu = engineerable to get it plated. Plus you save $400 on the PFC as opposed to getting the AP version (that's near a full tune).. readily available, and under the $1k mark. Plugs right in.
I've got the spreadsheet in front of me with the numbers, roy - it's not expensive. $2.5k for .. manual conversion + rb25 - sale of old rb20 parts. Just shop smart. My engine may not last forever, like any second hand engine, but there is always the option of an rb30det, or rebuilt rb25, or simply another rb25 to slot in. The framework is in place.
But each to their own :)
https://www.sau.com.au/forums/topic/124172-unhappy-camper/#findComment-2295794
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
