R32, 33, 34, S13, S14, S15, Wrx Leather/vinyl Seat Covers..
For my front covers, I am after the same look as the oem R34 S1 seats - M004 on the outer parts (and rear), and M005 or M006 centre (whichever colour looks most like oem) - and I'm after the centre to be the the wrinkle look (which I think should only be $25 since we are just getting the fronts, not the whole set done). Seat pic attached
  • Replies 215
Posted Images
Hey Jetdat, I've had a change of heart...
Could you please change me to both front & back in Charcoal (M005). For the sake of an extra ~ $100, I'd rather have it all matching.
Cheers
Actually mate, I'd like to change my front seat order to M004 outer and M006 inner (in the two-tone style in your sig), with the Nissan embossing. When would be looking to proceed with this?
Out of interest, how much extra for the rears? (same style, without embossing)
Thanks mate!
Thanks mate!
mate i dont seem to have you down for anything yet?? you only asked price and and i quoted...
i am putting you down for fronts only for r34... if we can get 20 people the front and back will be $400.
This looks awesome looks really good! I'm very keen!
I'm intrested in front and back seat covers for a 1993 GTS-T 2 Door Nissan Skyline.
What would be the price through the group buy? Thanks!
as per the first post if we can get 20 people, which i think we will, the price will be $400 front and back for any colours...
so are u a definate?
I'm not definate so don't put me down yet I am very keen however. My Skylines in the workshop and most of my cash is going into that at the moment. I will know more tomorrow and see what I can do.
So, it'll be $400 does that include postage or another $50 on top of that for postage to Brisbane?
By the way - are they easy to put onto the seats?
yes $50 for postage..
i have never put them on so i dont know but i doubt they would be that hard...
Warren has put them on his car yesterday perhaps have a chat to him, see his thread below..
http://www.skylinesaustralia.com/forums/in...howtopic=124841
Put me down for:
r33 gtst- full set - black with double red stitching
Mitsubishi FTO - full set - black with double red stitching
Put me down for:
no probs..
what if you get over 20 people does it go down anymore?
if you get 20 people or more im in..
well at the start they didnt think we could get 20 so they said $400 is for 20 or more...
if we do get more than 20 i will try my best to re-negotiate for more discount...
i am sure we can get 20+ so i am putting you in mate...
How much extra does the wrinkley look cost plus door trims, hand brake boot and gear knob boot cost?
wrinkle $50
dorr trims, handbrake, gear knob $150
BTW for guys in sydney, if you want I can pick up your seat covers and bring them up with me to Syd when I drive up in 3 weeks to save you guys $50.
Yea funks i will take you up on that offer >_<
OMG 18 people! put me down for front n back white (or cream whichever is available) with white/cream stiching for a series one r33 gtst.
how much extra for say the gear stick boot and handbrake boot the same colour as the seats?
when do they need the deposit?
putting you down...gear stick and handbrake $50 each...
once we finalise the group buy, b4 they order the covers i will ask for deposits...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
