hey fellas, i thought maybe some of u might be able to help me out here...
u can modify a car as much as you want but in all honesty, its your ability to drive that counts more than anything
my problem is that i cant seem to perfect my launch..so i was wodnering if anyone could give me some tips...usually i sit at about 2500 to 3000 and jus ease through the clutch, but i still get taken off the mark...eventually through 3-4 i can them most of the time but if i could jus master the start....
any advice?
https://www.sau.com.au/forums/topic/124595-the-perfect-launch/
i actually like a nice salad mayo sandwich, usually goes down and hits the spot nicely :whistling:
oh hang on, launch, hmmmm
anton sounds like you have the idea ... i would be more insisting on 2000 - 2500 rpm easing clutch out and gaining throttle as its coming out
a little wheel spin, or chirping of the tyres is fine ... just no major wheelspin.
its not as easy to launch as everyone thinks
unless u got an auto ... meh
Your avatar shows a R33, your sig shows "RB20DET" - so this might be of no use but...
My R33 (pretty much stock) launches best at about 4200rpms. Any lower, it bogs. Any higher, wheelspin to hell. But 4200 - I go off like a gunshot. It's very tricky (especially with a turbo), but once you find the sweet spot you're laughing!
Much easier if you get an aftermarket computer with launch control - you can preset the revs your engine holds at whilst you hold the throttle flat down, as soon as it detects any speed (cos you took your foot off the clutch) it goes bach to full...
I Have an R32GTSt. Mods are FMIC 3 inch turbo back eghaust, 12PSI Boost. I also have a semi button ceramic clutch. Launching was a hard task to perfect. Usually 3500 - 4000rpm for a "moderate" launch or a redline launch if out at the track and just ride it out.
For average day to day driving i usually take off at 1500rpm.
Hope this helps!
a little bit of wheelspin is better than bogging it down. i have a heavy single plate clutch and only have stock tyres (205's...i know they are crap, but my old ones weren't legal and i only paid $200 for 4 new tyres on stock r33 rims). putting 270 odd hp to the ground through them is rather tricky. i rev it up to about 3000-3500, load it up on the handbrake. then when you want to go you drop the handbrake, gas it as you let the cluth up quickly. use the accelerator to determine how much wheelspin you get.
Is the car in your avatar a GTR - or has it just been badged a GTR like some (i won't call anyone names) people do?
If so, up the anti and drop it from 3500 - 5500, that's the beauty about GTR's they stick, if not, 3000 - 4000 works for me.
Hmm Wheelspin... What if ur car is running on High Boost all the time??
how do u lessen as much wheelspin as possible
Sometimes i can smell clutch n it's burning or whatever
I rev it to about 1K or just a bit over.. Then Bang drop on the Gas
Still spins. Got 245'z Tyres, FMIC, 3 Inch Cat Back, Hks Filter n 9-10Psi of Boost. It doesn't get going till after 2nd... then goes all out once i reached 3rd..
It's a bit of a Problem when draggin other Fast Non-Turbo Cars.. aka V8's, SS, XR8 etc...
Edited by Black_CSR
  • 3 months later...
I rev till about 3000. Lift the bandbrake, let clutch out till the friction point and then release then hanbrake. I may not come onto boost as quick as the guys who drop and feather the clutch at 4000 but it's consistent.
Tyres and suspension play a monumental part aswell
Jeezus, this thread is filled with so much uncertainty that it's just not funny.
Few points for you to consider (for the drag strip of course):
A little wheel spin is better than bogging down.
Generally, this requires a little more revs, and easing the clutch out.
It is car dependant - therefore, you'll have to practice.
What I did before, was I would start at 3k rpm. I tried to pop it, it boged.
Popping it at 4 did a mini burnout, then bogged.
Therefore, for general semi quick launches, without absolutely killing the clutch, I just ease it out at about 4-4.5.
But hey, that's just how my car goes with my tyre, suspension, clutch, power delivery etc. Therefore, practice on your own car.
But the general principle is avoid bog, avoid burnout, a bit of wheels spin is ok e.g. 10% wheelspin.
hmm, when i had the stock 32 turbo, dropping it from about 2500 was the perfect launch. Now with the r34 turbo its impossible to take off. Wouldnt bother taking it to a strip, too hard to launch, id be looking at 15's.
I've tried riding it down from 4k, too much clutch burn, 3k, it bogs even if i let it slow or it wheel spins to the top and dropping it from everywhere means either bog or burn. I was driving my mates civic (91, twin carb, 1.6L), he was in my skyline, i was in front of him on take off for at least 50 meters, till spoolage and traction and lag fixed itself and the line overtook
gey assd rb20
Ok ill post a proper response about my experiences. In my old R33, it had turbo back exhaust, 10psi, Power FC, FMIC (191rwkw), rock hard tein susp, 5 puck brass button clutch, 255 wide K104 tyres, revs at 4200, drop clutch (foot flat all the way) & wheel spin half way through 1st, ran 13.5 @ 106 with 1.8 60’ (with granny shifted 3rd)
As adrian said, it's car dependant, so practice makes perfect.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
