Not Busy This Friday 7th From 7pm? Want To Drink Copious Amounts Of Booze Out East?
A local TMU guy that everyone is so scared of. I drive my thing around Knox all the time, and I've never been hassled.
If someone is willing to shout me drinks all night, as I have negative moneys until pay-day, I'll come down :]
  • Replies 57
Posted Images
I might be heading to knox tonight anyway so I might pop in and say hi, except I dont know anyone! chances are I'll end up going up to the wrong group of people and make a total d!ck of myself. :P
Edited by Ricey
im still crook with this flu shit.
Standing in the cold @ winton set me back about a week :(
Ill see how i go... im actually going to the quack later to see what the story is
Sif I look like him, OK maybe one night I was pissed, saw an upside down Friends cover and though oh sh|t, they are right......but no. I'll look something like this, but much more trashy tonight!
If you don't know anyone what better chance to meet ppl, come have a drink :D
Ash - Alcohol will make you well :(
Im am so glad we are getting messy tonight.
Worst afternoon ever at work. :) Gunna need a good night to lift the spirits.
Im leaving now to go home and get a head start on you guys.
See y'all there.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
