there is finally a workshop that can comply the 91-97 toyota aristos.
looks like it is time to sell the gts-t and upgrade to pimp style with 2jz-gte power
will be one of the first in the state and will look like this one
http://www.j-spec.com.au/list/index.php?ID=6840
probably stock but the same colour.
just got the personalied numberplate to go with it "jzs147" which is the chassy number so will be worth a mint when these bad boys take off.
loved the skyline but time for more room and more power!
keep an eye out for me in about 2-3months
woo
Edited by linxus40
https://www.sau.com.au/forums/topic/125138-aristo-time/
i wanted one of these before i got my first R32 btu they werent importable and even if they were they would have been tripple the price back then.
nice cars... need leather interior if you get one tho.
https://www.sau.com.au/forums/topic/125138-aristo-time/#findComment-2310880
Well done!! Another person has worked out Toyota's shit all over nissans. :O I recently purchased a jzx100 chaser and could not be happier. Previous rides were 180sx and laurel mint low km, and the jzx100 shits over all of these. So much better build quality. WELL DONE!! Aristoa's are the bomb. I wanted one b4 i bought the chaser but no compliance available either. :O Oh well. Sothe only real question now is when is the T88 going on??
https://www.sau.com.au/forums/topic/125138-aristo-time/#findComment-2316992
well the toyota supra with the same engine is like 1550kg's, aristo is 1700. thats only 150kg's. with a turbo, injectors, fmic, ecu, and a fuel pump ill be running with 400rwkw. thats a rocket
'Pocket' yes, 'Rocket' no...
That's like calling a 6 foot 5 girl a pocket rocket... :O
https://www.sau.com.au/forums/topic/125138-aristo-time/#findComment-2317044
Living in vic I wouldnt bother thinking of modifying to that level, if you would even actually do it.
Most of them that have come up seem to have alot of km on the clock
https://www.sau.com.au/forums/topic/125138-aristo-time/#findComment-2318484
These cars aren't new
I had a look at one for sale 2 years ago..
This was badged LEXUS and had the twin turbo set up, the dash was LCD and was very smart.
But hey guys if you think you can beat a gtr or any moded nissan in this luxo barge your kidding yourself :thumbsup:
https://www.sau.com.au/forums/topic/125138-aristo-time/#findComment-2318870
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
