God-dammit.
Justin wins again.
He has also volunteered to find the cars for the next mystery car bit in the newsletter!
But - I have a second place prize here for someone else to try and guess the cars.
Well done, smartass Crispy :)
Hehe, yeah I wasn't sure who was in charge of the comp this time...
I don't remember that, but very well, I shall attempt to use my powers for good, not evil :P
God-dammit.
Justin wins again.
Well done, smartass Crispy >_<
PM sent.
They were pretty easy. It might be a bit harder if they werent all italian.
Its a shame sau is blocked at work or i could waste my days on pointless crap like this.
PS. Let me know if your not happy with the name of the Alfa. Just found out it had a couple of names and wasnt just a prototype.
Nice work Tommy :sick:
You win 2nd place!
And yeah, these weren't as hard as last time. I was on an Italian theme.
Next issue - expect something much harder (and that's without Crispy influence - I have a new idea)
>_<
For those of you playing at home, we have:
1. Fiat Dino Spyder
2. Lancia Beta Montecarlo
3. Alfa Romeo SZ Zagato
4. Lamborghini Espada
Note different pix just to prove their existence as real cars :D
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
