Yeah,
Bayside Blue is by far my favorite color for the R34 series and it certainly is eye-catching. It took me ages to find a GT-V in that color. (they're quite rare and the color is in demand) Like I said, it was mainly the GTR's that were available in B-Blue, which works in my favor - most people seeing my car for the first time (or driving past me) think it IS A GTR, just because of the color!:P:(
Of course, anyone with even a little bit of knowledge about Skylines will pretty soon spot that it isn't a GTR, but still...
BTW - what is SAU? If you're refering to the forum, then I found it by following a link on the British GTR register (I'm a Brit living in Japan)
The Kakimoto is a great exhaust. It is a special version for N/A. It doesn't drone that much, but it can be a little loud (though its a matter of opinion), so I usually drive around with the extra baffle fitted in the tail...
Cheers
Dave
  • Replies 116
damn im determined 2 make my next skyline that colour!
Yep SAU is the forum it stands 4 Skylines Australia
Do you hav anymore info on that exhaust? im looking at changing mine and yours sounds pretty good ive heard of kakimoto before but i dont know where i can find kakimoto stuff???
  • 4 weeks later...
Originally posted by neoGT-25
Hey Nismodified, why are you buying a jap brand cat?
isent it cheaper to get a localy made item?
id love a A'PEXi exhaust system tho... but short on funds :D
Also... how many of us here with N/A lines have a jap exhaust compared to a localy made exhaust? also... what size are they? im getting a 2.25" front to back... is this a wise choise?
I got a catback lukey muffler and it makes the sweetest sound, i hate big bore cannon mufflers, they SUCK. and yeah why get a jap exhaust when the aussies make tough exhausts that make superb sound. mine is 2.5" i think, thats what the standard muffler was connected to as well form the extractors
i went for jap, because im a bit paranoid about making sure i get some power from the exhaust.
nothing in life is certain, but at least using jap settles my nerves a bit.
any way, i bought a 2nd hand jap cat for a good deal off a mate.
If i had a turbo, i wouldnt worrry as much about where to get my exhaust done.
currently, i have on a 2 3/4" 5zigen, it has a muffler as big as the stock muffler, one resonator. 3.5-4" tip.
very nice grumble while driving along, dead shit quiet after 3000rpm and at idle.
drony at 1900rpm-2900rpm
power seems to pick up well at about 4000rpm, it took me awhile to get used to the noise but i love it !
  • 4 weeks later...
I've got a R32 GTS25 2 Door...
2 1/2 inch exhaust with Kobe Extractors and resonators
GTSt 'Type M' Brakes (5 stud conversion) 17" Wheels
GTSt Viscous LSD
Currently fitting side skirts, and tossing up between putting a RB30 bottom end, or a RB25DET to get more horsepower
Currently 150kw at the engine
Originally posted by Nismodified
kobe extractors? Was that locally made or is that a Japanese made unit?
if you do proceed with the Rb30/rb25t conversion, i am very interested in purchasing your extrators.
I bought them from NZ, and put them on 3 months ago. I've been stoked with them. To be honest I wasn't expecting a noticable improovement, but the torque increase is great. I will be happy to palm them off to you, when I go ahead with the RB25DET conversion.
  • 4 weeks later...
Guest R33Glenn
lolzz...nismoman18, the nissan designers must have a short memory span, and your R33 looks dam sweet! talking of things in the boot compartment, i found some small Japanese fireworks and a old japanese lolly wrapper this morning, would of gave me a dam fright if those fireworks went off some how :P
with the badges, i also have red ones, i heard that i was sposed to have blue badges so i dunno..,. Also i was talking to someone about the battery thing and apparently its for better weight distribution (spelling) but i cant see how the weight of the battery could effect the handeling that much..... but yeah either way.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
