Well guys/gals - its finally here! My turbo back exhaust is complete! BATMBL s/steel front/dump pipe, large 3 inch catco cat and Trust PE2 cat back! About $1400 odd, for the whole lot including installation and it sounds great! (well to me anyway) Got RE Customs in Springvale (Vic) to install it - and yeah, it makes a whole lot of difference. Havent really taken the car for a good spin yet, due to the rain, but it feels a lot better to drive. Its extremely quiet too, until about 4000 revs - then it makes a howling sorta sound.
The overall installation was pretty much spot on - everything fitted perfectly according to Ray Evans. Took it in today at around 11am, was finished by about 3 (including my 5000klm service).
Will post up pics after I washed the car.
(Michael - batmbl - thanks heaps bud, was a great buy the dump/front pip and cat :P )
Edited by emsta2003
https://www.sau.com.au/forums/topic/125272-new-exhaust-updated-with-pics/
  • 3 weeks later...
Lovely exhaust... got one on my 34 :woot: You want it to sound even better? Get them to cut out the centre muffler (resonator) from the PE2 and replace it with 3" straight pipe... done that to a few cars now (all with PE2s) and they absolutely roar after!
Thanks bud - I am quite happy with the way it sounds, as it doesnt attract the cops - how much louder would it be without the resonator?
There are reasons for doing it though; not all for the sound...
1) The resonator (in my case) was hitting the uni-joint (???) after the split front/dump installation so it had to be removed to stop the contact.
2) The resonator on the PE2 is not straight; if you look at the entry and exit; it's actually off-centre. This can restrict flow... replacing it with a straight pipe will solve this.
stan, any resonators you cut off trust PE2s I would be more than happy to take off your hands. :woot: this goes for anyone else in sydney too.
how many have you got there? lol
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
