  • Replies 47
Posted Images
Bit harsh there Phil, he may own that R34GTR. Feel sorry for the owner, but that is why i don't like towing cars on hired trailers, that are not properly maintained. I have seen this too many times, to take the risk.
I drive a Ford, does that make me a dumb-ass too? (retorical question no need for answers thanks :sick:).
My Ford comes free. With free; servicing; insurance; petrol; etc (not so dumb after all, hey >_<)
I drive a Ford, does that make me a dumb-ass too? (retorical question no need for answers thanks :D).
My Ford comes free. With free; servicing; insurance; petrol; etc (not so dumb after all, hey :D)
meh, i get cut-off, tail-gated, blocked in the fast lane by fords, by far the most often so i feel i have justification to stereotype this guy :sick:
Just to stir the pot a bit more:
F.O.R.D - Fix Or Repair Daily >_<
Errr Hi everyone,
It is my GTR.
the accident happened a couple of weeks ago, and the only one injured was me - torn muscles in my back and neck (pretty much better now).
The car is not written off. In fact the damage was relatively minor and she should be back on the road hopefully by the end of August.
that is the grey 34 as seen at recent events such as Sandown. Poor Neil got into a spot of bother towing it down the hill past Pikes Ck on the Western Hwy and ended up killing BOTH his cars.
Don't put shit on him for driving a Ford. I've also got an AU. It's a bloody good car, possibly the sexiest four door ever made.
Thanks Aaron,
The ford was good - allowed me to get out of this scrape with minimal injuries - but as for the "sexiest" 4-door, I'm not so sure >_<
When I say "relatively'', if it was a commodore and not a GTR, it would have been about $12,000 to fix, but because of the price of parts etc on the gtr you can multiply by about a factor of 4!
All panels down the passenger side rooted, nose ripped off (going to put a nismo front bar on as a replacement), passenger side suspension components damaged etc.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
