have a look a this link I thinck it mentions something about, The unique ported shroud was designed to minimize compressor surging at the mid-range rpms.
http://www.dragsport.com/issue/2006/0706_tech.shtml
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2322509
RBSandy they are the vent paths for the ported shroud within the inlet boss . 2rismo I'm not sure what you mean by they are covered by the filter or inlet ducting ? So long as the vent paths can vent air from the radial slot in between the main and splitter compressor blades to the atmosphere side of the boss they will work . I have a feeling that HKS do this partly for bling factor (marketing) but I also get the feeling that doing it like this or by having the trumpet mouth insert like say their GT3037's have reduces the shrieking screaming noise that the more common port shroud like say a GT30R (GT3076R) tends to have .
Thanks for the link as well , always wanted to see inside the HKS TO4Z comp cover .
Cheers A .
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2322654
the holes on the comp cover are a workaround for compressor surging
it allows air to enter onto the compressor wheel on the outer edge to balance out the some of intake sucking, which is commonly associated with surging. think of it as an anti surging device.
the bulk of the air enters the snout, thanks to the vacuum effect of the compressor wheel sucking in air, but a very small amount enters through the holes also to side step around surge
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2322783
wonder if it would surge with the holes blocked off. logic would say yes.
i guess that was the only comrimise they could come up with to avoid surging. must be a really wacko compressor/housing combo (sounds logical??)
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2324260
It's not very hard to picture. How many of you run no filter on your turbo? Do you all have a pipe from the compressor inlet to an air filter? Would the holes be obscured/covered on a T04Z like this?
Tell me what they're for in that situation?!?!?
Adrian
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2325025
2rismo I can't follow you logic , if you mean "covered" as in out of sight then 99.99% of port shrouded compressor covers the world over are covered . This does not prevent them working as they were designed to . Many Diesel turbos have port shrouding and very rarely are they run without ducting to an air filter . If the manufacturer wanted it not to work the gas ports would exit the cover through the outside of the boss ie the parallel section behind the barb .
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327007
asmuch as i would like to believe that its just bling factor, HKS have obviously done some R&D into this turbo with a particular housing combo and realised it surges, whether its engine and boost specific or whatever. 2rismo, doesnt matter if thier plumbed back into the induction pipe. thier there to releave flow when its surging.
and if its all bling why wouldnt they do it with all thier other turbos?
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327095
Adrian
I dont get what you mean either, the pipe sits OVER the housing, not inside it.
So the holes, no matter if a pipe fed the bellmouth or not, would still flow air as designed
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327252
Adrian
Im not getting you either :wave:
Silicon joiner gets hose clamped to the outside of housing, holes on inside. Why would the holes be obscured?????
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327260
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
