Sounds like you're a regular up there Luke, somethin we should know about?? :thumbsup: Don't tell me you've been borrowing Michele's whistle......
LMAO - For Sale... one slightly used whistle, the type you blow... :) errm let me re-phrase that... :D
We are talking about going up to the lookout on Friday 24th for the photos as there are a few where this Friday was too soon (working, rego etc.)
So what's the plan for this Friday so far?
  • 3 weeks later...
Might do if theres a few others keen.
I'm so chuffed my car is now ACT registered and not leaking exhaust at all < :D > and thus running heaps better! and with help from Frink I have a new set of Feds which i've just about worn in.
Cool,
Federal's on a GTR.... Niiiiiiiiiiiiice! :)
If you need any info on pressures, optimum temps or anything technical on them, I can help...
Im the Federal Tyres guy around here (aswell as Frink). :D
Edited by Bullet32
Federal's on a GTR.... Niiiiiiiiiiiiice! :D
I'm going to have Federals on a GTR when I wear out my current ones
Im the Federal Tyres guy around here (aswell as Frink). :)
He is also the "Frangipani Guy" around here :D
  • 4 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
