i just added a hiflow turbo to my skyline
it has these mods
apexi
3inch dump pipe and exhaust
Z32 airflow meter and pod
gtr fuel pump
front mount cooler
blitz boost controller
high flow ball bearing 450hp turbo from turbo australia
standard manifolds
on 10psi it made 251rwhp but ran into nock problems
at 13deg timing could not run any more boost or timing into it ...
The nock would go to high .
they even richened the fuel up at the top end .... to stop it knocking but this did not help
It would not knock till right on 6200rpm ....
Any one else seen this problem before ?
dnyo sheets are here http://www.tuffstreetcars.com/skyline2.pdf
http://www.tuffstreetcars.com/skyline.pdf
https://www.sau.com.au/forums/topic/126291-hi-flow-turbo-problem/
He will be running a SAFC which you can run aftermarket AFM's with. . The SAFC has limitations you need to compromize between your air/fuel ratio and timing this is fine with the stock turbo but it starts to get difficult when an aftermarket turbo is added to the mix. Its probably time to invest in a Power FC or similar you will probably also need to upgrade the injectors.
cheers
cheers
sorry i have a power fc just tuned on the dyno ....im not using all of the injectors i have yet as i cant up the boost or timing as the knock goes to high looking at the turbo housing size ....right now but im not sure thats why i asked
Looking @ the dyno sheet, the tuning is nothing short of below average.
Has the tuner got expirience with PowerFC's ... and turbo performance in general ?
Whats the fuel pressure like?
Personally i would say the problem begins and ends with the workshop you have there.
I would go somewhere else for a secondary opinion.
Might cost some $$ but i would think it will save you some hassle
Seconded
How can you have a power fc and a stock ecu? Piggybacked due to auto?
If it is a power fc tune then that is sub par, I agree with nismod, safc then acceptable and also explains your detonation issue and having to mess with the base timing rather than the specific cells where the detonation occurs.
yeah that's a pretty rough power curve. can see his mods to the AFRs were decent but the power is still quite ordinary.
Time to go for a full ECU, rather than a piggyback. If that is a full ECU then get a better tuner.
it has these mods
standard manifolds
A little off thread Dan, but do you know the ID tag numbers off your hi-flow core?
The guys from Turbo Australia are pretty good, just interested to see what specs they ran for your unit.
I'd have a few concerns about the output, given I achieved 223rwhp with a stock turbo @ 7.5psi and other similar supporting mods to yours. Look at the tuning I suspect.
cheers
Edited by Dale FZ1
cheers
hi i dont have the turbo now its back at there shop ...till they sort it out, stock one is back on and feels a lot better then the high flow right now ...so im not sure what the problem is
yeah sorry was late when i posted it just has the power fc handcontroler
Have you taken it somewhere else for tuning?
these are the guys the turbo shop wants to do the tune on it ...
when i bought the turbo i was told they done a lot of the 450hp hiflows , only to find out im now the first one they have done so they are trying to fix the problem best they can .
Edited by Turbo Dan
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
