grrrrrrrrrrrr
the guy from VDO emailed again, and even with the nissan part number that i gave, he still says there is no VDO item!
I gave him the part number that was in the aus300zx.com website to see if he has that in his stupid computer. i have no idea why its not coming up as a listing...
will keep you posted.
Warren
ok more bad news..
the moron at VDO who is emailing me, still insists they don't have a OPS for us
he won't confirm that the 300zx sender works at all.. he is dodging the question coz he is a f**king moron
i'll have to do some more searching i think
is it 100% confirmed that its the same sensor for 300zx/R32/R33??
what about any other nissans
thanks
Just some observations that might help:
1. Genuine OPS from Nissan is around $150 (trade....add maybe $20 for retail).
2. OPS PN is 25070-30P01 (R32 GTR and GTS4, R33 RB25DET and Z32 300ZX). FAST does show an alternate number for some models (25070-55S60), but it also shows the -30P01 as the direct alternative.
3. The VDO OPS shown on the 300ZX link looks identical to the type fitted to local spec R31 Skylines (RB30) as standard. VDO supplied some parts for Oz spec R31's, inc the instrument cluster and some other sensors, basically to build up local content. Be warned that quality is not great.
well spokt to some people who have done this on their 300zx, and they have confimed that te unit does work fine, but still suffers from the same problem as the stock OPS
this leads me to believe that the problem is not the OPS unit itself, but something aboutthe way it is mounted or connected
there's nothing wrong with the stock OPS...
the only thing wrong with them is the fact that they're getting close to 15 years old and as such, are f**ked.
what happens is the rubber seal around them fails, and lets oil inside the unit itself.
from what i've heard, if you replace it with another factory one (or in this case a VDO one) it should be fine for another 15 years.
*note* this is what i've been told in terms of why they play up etc
well i have spoken to a good mate who is a member of aus300zx.com
he said he changed to the VDO sensor and it failed in 4 months
then he changed to the stock sensor and it has been ok for about 6 months so far
BUT.. he did some kind of electrical modification to the OPS before he putit back on
apparently (according to him) there's 2 plugs on the OPS, but the stock wire only connects to one of them
He grounded the other plug to the chassis... and he hasn't had a problem since...
apparently an autoelectrician told him to do this
I want to try it out, but haven't had time to try and get to the OPS
  • 4 years later...
Hardcore thread bump.
Has any one used an aftermarket oil pressure sender to replace the factory unit?
I want to wire in an aftermarket oil pressure sender into the Vipec as a fail safe (if it sees less than 5psi to shut the engine down) but want to do it with a new oil pressure sender as my stock one acts up.
  • 4 years later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
