i got plans to purchase a R31 GTS-R and put a RB26DET in it or even a RB26DETT in can ethier of these 2 engines fit? o and wanna know something?? this is my research ah ah ah but i think this would be a ultimate diffrent skyline on the roads as they are rare cars but do pop up for sale from time to time be fun to work on from scratch!
cheers
Edited by _Victory_
https://www.sau.com.au/forums/topic/126701-rb26-in-a-r31-gts-r/
Not ultimate different...
I've just about finished doing it to mine :blush:
For the cost price of a GTS-R... around the 15k mark... then the RB26 everything else like g/box etc.
Your looking at around 25-30k depending on what you want to do.
Can easily top 30k total cost... Or start from a GTS Turbo coupe @ a cost of 5k rather than 15k
Price of a GTR it is... but ive had this car for a few years and my GTS-R came that highly modified from Japan so fitting an RB26 was kinda a mute point.
But i would NEVER modify a stock HR31 GTS-R. To me its a waste of money... unless like mine, totally non-standard already
Your skyline sounds awesome R31Nismoid got a link to pictures if you've posted on the site? what where the power figures when u imported it in?
Well where i live probally never has a R31 GTS-R ever driven on its roads but with those figures you have shown i could buy a R32 GTR V-Spec II or a R33 V-Spec casue i am upgrading car in a couple of months as you probally know i own a R33 GTS-T and like every other place theres a fark load but not many GTR's so seprating to a RB26 powered R31 GTS-R or V-Spec would be a ultimate diffrent i do have a fair amount off $$$ to spend too me it wouldnt be a waste of money as i find it fun getting stock cars and turnin them into nice looking beast's we just finsht installing a workt 4G61T engine into my mates lancer but if i did install a RB26DETT into a R31 GTS-R what do you think the 1/4 mile time be around? just seein if it is worth it not much information is avaliable with this conversion.
thanks for the help
Edited by _Victory_
if you want to spend $$ on a hr31 coupe you'd be better specking to a broker to get one imported, maybe something from r31house might be what your after, please use a gts-x not a gts-r, save yourself $10,000 if your just going to put an rb26 in there anyway...M2c
if you want a gts-r there is a bloke here on the gold coast selling one in mint condition something like 80,000Ks on the clock for $15000 or something close....
there was a gts-r on j-spec, with a 26dett w/ AWD for maybe 11,500 excluding compliance about 3 weeks ago. had fat wheel arch flares and uber-dish rims... id be checkin and seeing if its still there, hey.
cheers
The way Victory tells the story, RB26's came from the factory with either single OR twin-turbo setups :)
In answet to the whole thread....an rb26 will bolt straight in to an R31 with the only changes being the sump and you need to fit the engine mounts off an RB from an R31. I also had to slightly massage a section of firewall behind the rear turbo to give slightly more dump pipe clearance also.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
