hi guys
want a tacho for d4d this saturday. mine doesnt work. what are the rules about mounting them? my friend had one on a vl on the dash but had to move it an inch accross to get a rwc. ive read on here that you cant have anything above the stock instrument cluster. whats the go? thanks jason
Really?
Then where the heck are you supposed to mount a boost gauge?
Putting it above the dash makes a (small) blindspot, putting it in the air vent hole maks it too far out of the way to see.
WTF?
mmhmm well from what i heard... chu can have any sort of gauges places anywhere only "within" your vechile... and so the external ones aren't consider road worthy :)
http://www.vicroads.vic.gov.au/vrpdf/rdsafe/vsi%208.pdf
This link has some info about legalities of external gauges. Hope this helps :domokun:
- Patrick
My friend who is a TMU officer went and asked superiors caus he wasn't sure and was told: nothing higher than 30cm from the bottom of the dash or it's an obstruction of vision.
And yes we both agreed that was ridiculous. I'm not sure if he was specially referring to a 180 but it's pretty ridiculous either way, I don't even know what you'd count the 'bottom' as... maybe the cluster or the plastic piece below it?
I think mounting on the pillar is even defectable in QLD now. Definately not legal in VIC.
Thanks Kaz, shame :wave:
Also thanks for the link Rekin
I had an a-pillar boost gauge, and it never caused a problem.
There were a few queries about my placement of the AVCR/RSM - but mainly for it being an EBC rather than where it was.
I personally wouldn't stress too much... but there is a difference between a 52 or 60mm gauge an one of those Flava-Flav style monster tachs.
Have you thought about an RSM?
Shows your RPM and can be a bit more flexible in it's placement.
BTW: the new toy has some DEFI BFs fitted already - they are on the DEFI stands on the dash to the right of the binnacle - so the bottom of the a-pillar.
Should be as legal as you can be.
DEFI stands here - http://www.nippon-seiki.co.jp/defishop/pro...p/op_bezel.html
J
it cannot be higher then the lines of the dash.
The thing i dont understand is that its an obstruction of vision yet taxi drivers can have there stuff mounted all the way up the A piller with no issue.
Yes its a there job to take people around, but there only normal drivers and why does it exempt them from obstruction of vision, they are still normal drivers
Alan, get a gauge pod that sits on the dash, looks OEM
Thanks Dark but I dont like the placing of them. :(
My favourite place is the A-Pillar as I dont like cluttering the dash. I dont mind them in the dash but prefer them in the A-Pillar.
Thanks Dark but I dont like the placing of them. ;)
just do it :(
its not hard to take it off if you need to clear the defect...and i got myself a spare pillar plastic (which already had a hole hacked into it in the perfect place for wires :)), so that if i ever change my mind, I'll put my plastic back on and have a hole free interior :O
that was one of the specific things i looked for when importing my car....didnt want 1 that already had gauges etc all over the place, because i didn't want holes everywhere
So long as you're looking at a sensible sized gauge - I honestly wouldn't stress about it.
As long as it doesn't impede your vision - nor sit as an obvious hazard, then do it. Worst case, someone will ask you to move it. The HUGE gauges are just stupid for street use anyway.
Here was my old setup (sniff) - as I said, a-pillar and RSM/AVCR were never an issue.
Don't know where you guys are getting your info from but I looked into this pretty carefully before fitting my gauges. According to Vicroads (unless someone corrects me otherwise) -
* the gauge cannot obstruct the drivers vision
* the gauge cannot be put in a spot where either the driver or passengers head would make contact in an accident. ie no a-pillar, not on the 'front' face of the dash (like just above the glovebox in a 33)
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
