hi guys
want a tacho for d4d this saturday. mine doesnt work. what are the rules about mounting them? my friend had one on a vl on the dash but had to move it an inch accross to get a rwc. ive read on here that you cant have anything above the stock instrument cluster. whats the go? thanks jason
Really?
Then where the heck are you supposed to mount a boost gauge?
Putting it above the dash makes a (small) blindspot, putting it in the air vent hole maks it too far out of the way to see.
WTF?
mmhmm well from what i heard... chu can have any sort of gauges places anywhere only "within" your vechile... and so the external ones aren't consider road worthy :)
http://www.vicroads.vic.gov.au/vrpdf/rdsafe/vsi%208.pdf
This link has some info about legalities of external gauges. Hope this helps :domokun:
- Patrick
My friend who is a TMU officer went and asked superiors caus he wasn't sure and was told: nothing higher than 30cm from the bottom of the dash or it's an obstruction of vision.
And yes we both agreed that was ridiculous. I'm not sure if he was specially referring to a 180 but it's pretty ridiculous either way, I don't even know what you'd count the 'bottom' as... maybe the cluster or the plastic piece below it?
I think mounting on the pillar is even defectable in QLD now. Definately not legal in VIC.
Thanks Kaz, shame :wave:
Also thanks for the link Rekin
I had an a-pillar boost gauge, and it never caused a problem.
There were a few queries about my placement of the AVCR/RSM - but mainly for it being an EBC rather than where it was.
I personally wouldn't stress too much... but there is a difference between a 52 or 60mm gauge an one of those Flava-Flav style monster tachs.
Have you thought about an RSM?
Shows your RPM and can be a bit more flexible in it's placement.
BTW: the new toy has some DEFI BFs fitted already - they are on the DEFI stands on the dash to the right of the binnacle - so the bottom of the a-pillar.
Should be as legal as you can be.
DEFI stands here - http://www.nippon-seiki.co.jp/defishop/pro...p/op_bezel.html
J
it cannot be higher then the lines of the dash.
The thing i dont understand is that its an obstruction of vision yet taxi drivers can have there stuff mounted all the way up the A piller with no issue.
Yes its a there job to take people around, but there only normal drivers and why does it exempt them from obstruction of vision, they are still normal drivers
Alan, get a gauge pod that sits on the dash, looks OEM
Thanks Dark but I dont like the placing of them. :(
My favourite place is the A-Pillar as I dont like cluttering the dash. I dont mind them in the dash but prefer them in the A-Pillar.
Thanks Dark but I dont like the placing of them. ;)
just do it :(
its not hard to take it off if you need to clear the defect...and i got myself a spare pillar plastic (which already had a hole hacked into it in the perfect place for wires :)), so that if i ever change my mind, I'll put my plastic back on and have a hole free interior :O
that was one of the specific things i looked for when importing my car....didnt want 1 that already had gauges etc all over the place, because i didn't want holes everywhere
So long as you're looking at a sensible sized gauge - I honestly wouldn't stress about it.
As long as it doesn't impede your vision - nor sit as an obvious hazard, then do it. Worst case, someone will ask you to move it. The HUGE gauges are just stupid for street use anyway.
Here was my old setup (sniff) - as I said, a-pillar and RSM/AVCR were never an issue.
Don't know where you guys are getting your info from but I looked into this pretty carefully before fitting my gauges. According to Vicroads (unless someone corrects me otherwise) -
* the gauge cannot obstruct the drivers vision
* the gauge cannot be put in a spot where either the driver or passengers head would make contact in an accident. ie no a-pillar, not on the 'front' face of the dash (like just above the glovebox in a 33)
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
