Can someone draw the driver a diagram so he can figure out what an apex is? It seems like its an accident when he clips an apex, rather than when he misses one.
Can we confirm if its an R8? Audi races them at Le Mans, and a hillclimb seems a bit tight for a car designed to do over 370km/hr down the Mulsanne Straight. And it doesn't sound like a 3.6L twin turo V8.
It looks more like a Westfield / Radical car to me...and if it had a worked bike engine then it would swallow gears like that.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358294
Don't know about all the spectators standing pretty well on the road though as he comes blasting through... couldn't think of anything more dangerous
How about Rally, where the spectators / photographers stand on the course, jumping out of the way only when the car approaches?
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358303
dont be too hard on the poor guy scathing! I would say he's not a pro driver, more just an owner/driver enthusiast. He does move his hand around the wheel alot which suggests to me that he hasn't had a lot of experience in prototypes or open wheelers. I didn't think he was doing too badly overall. yes he is pretty wide a lot of the time but that may be for safety as much as anything and it may be the quickest way through the course in a car like that. it certainly is an awesome hill climb course that's for sure.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358386
Hey, if it was me in that thing you could probably drive another open wheeler between me and the apexes :wub:
I probably wouldn't be posting it all over the Internet though. :D
But that hillclimb looks a lot more fun than Huntley, which is the only hillclimb I've ever done. I'd love a crack in it in my car.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2359312
You would use a totally different line when raciong down a open road by yourself, compared to racing on a track with a need to defend a racing line.
His Class time on the day would decide if his good or not.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2360295
And the biggest difference between a hillclimb and a circuit is how many laps you get to do in a row :angry: this run is pretty long/lots of corners it would take a while to learn perfectly.
But after doing a few hundred laps of a track you could do it inch perfect in your sleep
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2360695
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
