$90 was asked for in the other thread/forum. My offer stands if you can't move it, and offers aren't leaping your way. Not really worth anything more to me since I don't have a 32 and was just grabbing it as a gift for a mate.
Plus I expect a well modified stock airbox with Apexi filter will flow as well and doesn't introduce oil to your intake.
It is for a 32 GTS-t I dont have any photos of it on my car. You dont need any intake piping because it bolts onto the AFM. Yes it does come with the pannel filter. Im not taking $90 becuase its work $650 and $90 is practically giving it away. Any othey questions feel free to ask
I've got one of these in my 32. I did a "McGyver" on the frame that holds the panel filter so it uses foam instead cos the price of a proper ARC filter was way too much for my liking. Still works great but it isn't a true cold air setup as it sucks air in from the top. I've got a pic of my engine bay if anyone would like to see how it sits in there...
As lexbomb said it bolts straight in plus I've had a qld state traffic taskforce tosser look over it and not defect me for it.
Don't ask me what it cost cos it was in there when I bought the car but its definately worth more than $90...
Hope this helps your sale lexbomb!
It also comes with mounting brackets. It pretty much replaces your existing Air box with this one. It bolts onto the AFM. Its very simple when you look at it. Are you actually interested?
I'll send you a PM.
He has got it down packed thats almost exacty what it looks like. My car went through regency with it on and passed with it on. No it does not have an inlet trumpet.
Any more questions feel free to ask.
Lex-Adelaide
i have one of these in my car
it needs the inlet trumpet because thats
what the bolts that hold a/f meter screw
into, they are a good product.
i got a new genuine arc filter from shift performance
for about $120.00 also they are meant to be a
dry filter without oil hope this helps
also i have made an alloy divider that sits up around the
3 sides of the box and seals up against the bonnet
with rubber door seal.usuing the bolts that hold the filter
down.
i have a pipe ducting air from lh vent up into
the factory intake hole.
works really well
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
