First problem i can see with that is the 90 degree silicone joiner from the turbo outlet...the radiating heat of the s/s manifold will weaken the back part of the joiner and it will eventually blow through :laugh:
Two race meets our one lasted, then i had to tig an ally 90 pipe on to replace it. Not having a go at your setup...it looks very nice. Just giving some warning. Being a street car, it might hold up alot longer, but my money is still on that it will go sometime. Maybe wrapping the manifold? Could help.
Very nice though :wub:
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364487
First problem i can see with that is the 90 degree silicone joiner from the turbo outlet...the radiating heat of the s/s manifold will weaken the back part of the joiner and it will eventually blow through :teehee:
I would have to agree.
Also what exhaust manifold are you using?
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364846
Same thing happened to mine on front straight at PI.
Very hard to figure out when it first happens coz you can see the crack until you start pulling things off
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364886
I would also agree, based on personal expirience, i went through 2 90 degree bends :P
The heat from the exhaust housing just burned a hole through the silicone in a matter of weeks.
And fullboost @ 4500 :teehee:
I bet fullboost = 5psi
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364894
IT WAS 12 PSI
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2364944
You will need to replace that 90 degre bend as i have had the same issues...
I have also found that the chinese manifold ok to around the 280-300rwkw area but anything more than that and they will crack and bend. The stainless is just not strong enough to hold anymore heat...
Also you want to insulate your down pipe from the back of the turbo with heat tape to aviod affecting you air conditioning pipe work...
Other than that, she looks great...
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365502
The dump pipe is thermo wrapped....i tried to tell him to ceramic coat the manifold but he likes the bling factor. The manifold is no cheap "chinese knock-off" either its a well constructed local item with the runners extending right through the flange plate to the ports...it could have had a support tab welded to each runner for added strength though.
EDIT: many thanks to GCG who provided us with the "bolt on" water and oil feeds...."bolt on" yeah right!
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365523
HAHAHAHA
GCG supplied me some 'bolt on' water and oil feeds....
The oil return is not really designed with a high mount in mind. As it touchs the manifold so im gonna have to run the turbo on a slight angle to make it all work with out burning anything... :whistling:
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365615
Arhhh i could not see the rear... I just assumed it was not done...
PS. I am using a chinese manifold and she is working quite well but have been told not to push it too far...
Im only after 270 or 280rwkw anyways...
https://www.sau.com.au/forums/topic/127911-t04z/#findComment-2365620
