Shit, V-SPEC 2!! Nice
Must be a 94 then yeah?
As far as I'm aware, it's a V-Spec 1 with a V-Spec 2 sticker (As it's a '93). I'm pretty sure they didn't make V-Spec 2s in 93, but I might be wrong.
It came from Japan like that.
https://www.sau.com.au/forums/topic/128192-my-new-toy/#findComment-2369260
Nice ride mate! Very clean example!
Is that a 4.5 grade?
The auction sheet said 3.5, but it must have been pretty strict, because I can't see much wrong with it myself. Only a little pin dent above the front left wheel and a few tiny scratches.
https://www.sau.com.au/forums/topic/128192-my-new-toy/#findComment-2369264
those rims are standard for the 32 V-Specs aren't they?
EDIT: interesting one, this one. Prestige was selling it as a V-Spec II and i think J-Spec were rightly pointing out that it was only a V-Spec.... hmmm
https://www.sau.com.au/forums/topic/128192-my-new-toy/#findComment-2371603
