Cam Gears, Adjusting me and a mate where talking about my skyline and getting 200rwkw I said I need a computer and a Adjustable cam gear he said try and skip the belt over one tooth that should be about -4degrees and see how it goes, what do you guys think about this could it work. :cheers:post-28604-1154350017.jpg
Edited by RB SANDY
https://www.sau.com.au/forums/topic/128342-cam-gears-adjusting/
so are cam gears really worth it
I'd say its different for every car
Cam gears do give you a lot more options with tuning and your powerband, such as:
Advancing Intake and Exhaust: This will provide the car with more bottom end power, and will decrease top end. Advancing both cam gears will move overlap earlier but will not increase it.
Retarding Intake and Exhaust: This will increase the cars top end, but will decrease low end. Retarding both cam gears will move the overlap later and but will not change the amount of overlap.
Advance Exhaust Only: This will help the cars top end, and it reduces overlap.
Retard Exhaust only: This will help the cars mid range power, very useful for cars with big turbos / big cams. By increasing overlap, It decreases lag significantly. Doing this will bring the boost on all at once.
Advance Intake only: This will increase overlap and helps the cars bottom end and mid range power. This mod will bring the turbo on all at once.
hang on are you saying you want to buy cam gears and adjust them one notch... or are you saying that the alternative to buying cam gears is to skip one tooth on the stock gears??
each tooth is 15deg, so skipping one tooth, as you say, will make it way way out and is a stupid idea
Mate I have looked into this and it comes down to this some people gain power some do not. Im getting my 100K service done shortly and getting a exhaust cam gear installed while I am at it. Apprantly the idea is to retard the timing by about 4 degrees it is meant to give you increased midrange and top end power. I will get the car dyno tuned and post before and after results.
mods are
full 3" exhaust
intercooler (hybrid)
11psi boost
safc2
195 rwkw
cheers
some people say you can gain up to 10hp
If you can feel a 7kw difference... that will surprise me.
Im yet to see conclusive evidence the cam gear will be of benefit on an stocker RB25
RB26, lots to gain, but you dont have one of those.
on a side note you can use the stock cam gears with a dongle fitted to adjust them. mine has a dongle fitted to make the exhaust side adjustable (gained nothing). so you can retain vct and have them adjustable
everyone is missing the point here...
HE WANTS TO ADUST HIS TIMING BELT WITHOUT ADJUSTIBLE CAM GEARS
that's right, with stock gears
this is NOT possible. please DON'T do it. ditch the idea completely.
That is all.
Correct, some one picked up on it.. You need to adjust the actual cam shaft not the gear on the belt.. If you wish to invest in such item take it to a workshop that can do the work for you.
i suppose in ways your right but what your talking about is really inefficent. what u want to do is to increase the overlap keeping it symetrical. u want the intake to open earlier and the exhuast to close later by the same amount. so really u want to advance the intake and retard the exhaust. Defintly do not time the belt incorrectly by one tooth because theres a big difference between the valve being open enough to pass gasses & the valves hanging down low in the path of the piston. In respect to do they make a difference i say yes. it works on the kadenacy effect. it already exists but you just take further advantage of it which is exactly how extractors work and we all know they make a difference. it's also what vtec does & we all know how much power honda can get out of a na 4cyl engine.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
