Guys,
A little bit of background: My boost is set to 10-11psi using a bleeder valve (Turbosmart) I have stock IC, ECU. I have an exhaust, POD, CAI, usual stuff....
I found that if I increase boost to say around 12-13psi, when under load at about 3000rpm, the car will jolt violently for like half a second, then resume accelerating.
I have since then wound the boost back down to 10-11psi and when in 5th gear, cruising under 3000rpm on the freeway, it's fine. As soon as I put my foot down, and boost climbs to 10psi.... at about 3000rpm the car will jolt violently then continue.
I've worked out a few things:
It's not detonation, as the boost _really_ isn't high enough to cause a problem.
I'm 90% sure it's not misfiring, as I've had that before with bad plugs, and is fixed. I have copper plugs gapped to 0.75
Similarity: I've had the exact same jolty feeling if I've got under a 1/4 tank and hammering the 'go' pedal around a corner, Obviously the fuel isn't getting in there somehow, but then again It's coz i'm low on fuel :P
One more thing:
When boost climbs to 13psi it SCREAMS (the noise I mean) gets really loud... very loud induction/turbo spool noise. Is this normal?
Does anyone have any ideas?
-Kym.
https://www.sau.com.au/forums/topic/12839-car-jolts-violently-on-boost/
... maybe the fuel pump.... not enough juice to feed the cylinder's on strong boost.....
The turbosmart thingy could be the culprit..... throwing the "Spool up boost" past 12psi on "slam foot on floor" boost....
rough guess on my behalf
I'd say you're hitting the AFM voltage sensed boost limit (usually ~12psi but it depends on air temp/density).
If you feed the power on even at 13psi you probably don't experience this jolting right? But if you nail the throttle is jolts.
This is due to the rush of intake air through the AFM as the the turbo spools up suddenly. This sudden rush of air causes the AFM voltage to exceed the AFM sensed boost limit. When you feed the throttle on the turbo doesn't spool up with such a big rush & the airflow through the AFM doesn't exceed its voltage limit.
The cooler the ambient air temp the lower the boost level that this will occur. Cool air being denser means more air through the AFM & higher voltage levels. A -2'c morning & don't be surprised if it cuts @ 10psi.
I agree with "whatisname". I'll be expirencing this morw with the cooler weather coming in soon.
The bleed vavle may not be the problem, I have a Turbo XS bleed vavle and have NEVER had a major spike. My car has been set to 12psi and never had a problem (I've removed the little rubber hose which goes to the boost sensor, so it can't read an.) over boost.)
A few more things..how are you reading boost ? if its a aftermarket gauge where is tapped into ? do you have a atmo. BOV...is it dirty or worn and could be venting under boost load ?
After having a look at those things, I'd be cleaning your AFM (carfully with silicon spray) and taking the intake pipes off and spraying some carby cleaner down the intake manifold...
after that, I'd considar the boost cut/fuel pickup problem..
Cheers
Guys, thanks for the replies..
whatsisname: Yeah, that's right, if i feed it gradually it's fine. If i nail it, it jolts :P
PeakRPM: I'm reading boost where the stock BOV was connected. This is now connected to another vacuum hose that used to goto the Blitz bov (disconnected properly)
Metblue: Well, I know what the POD filter sounds like... kind of a "hollow" sound if that makes any sense.. but this sounds like air rushing out of a full compressor.. it's REAL LOUD... hmmm makes me think.
Strich9ine, more than likely it is an AFM voltage cut. Had the same experience when setting up my bleeder. On top of whatsisname comments, also be weary of the accuracy of your boost gauge. I was hitting the cut at an indicated 10psi, which was way off.
Originally posted by SHUTO-BOY
im gonna ditch my bleeder valve,i hate the jolting(its more like "pushing back") get an electronic boost controller. A fuel cut defender, or even better ecu and delete the airflow meter
EBC may help hold boost better but it won't get rid of the AFM cut. Fuel cut defender will do that, but its fairly dangerous without aftermarket tuning to match. The AFM cut is there for a reason and getting rid of it while running stock fuel maps is a recipe for disaster. Personaly, I don't see any reason for deleting the AFM. Its a great measuring device (better than using MAP for road driving, IMHO) and isn't a huge restriciton like a flap AFM or Karman Vortex MAF. Only downside is really the reliability of the AFM.
Before anyone tries this and gets into trouble, WD40 and AFMs do not mix well! Use electronic contact cleaner (1st choice) or carby cleaner (2nd choice).
Kim, Its your boost cut. Boost cut is set at about 14.5 pounds, but what is happening is that your putting your foot down in too high a gear without enough revs. This puts a lot of pressure on the engine and the boost goes straight up extremly fast!
I bet you take off from the lights, red line first, red line second, redline third no worries. But say cruising in fourth at 60, put your foot down and it does it. Always drop back a gear or two.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
